Oil filter stuck
Old May 21, 2014 | 04:57 PM
barngal6's Avatar
Oil filter stuck
98. 12v. Oil filter is stuck on. I didn't remove the top bolt initially, so I cranked on it a little. Then I was able to budge it in the right direction, got a little easier, then stuck. Oil is drained. Can't leave truck it where it is
Please tell me there's a trick or technique. I'm obviously not that strong, and there's Not much room in there...
Old May 21, 2014 | 05:29 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
The only trick I know is to be sure and remove it when the engine is warm, they will grip like all get out cold.....
I use a Big pair of channel locks on my 12 valve....wish I had a magic cure for you but that is all I have...Good Luck!
Old May 21, 2014 | 05:31 PM
sherod's Avatar
second vote for channel locks. Second best is oil filter pliers.
Old May 21, 2014 | 05:48 PM
barngal6's Avatar
Ok I made some room in there, but I got a spark with the channel locks. Guess I need to disconnect the batteries, there alt is right there. If this doesn't work, can I cut it off?
Old May 21, 2014 | 05:56 PM
Nughuffer's Avatar
Hammer and a flat head screw driver.
Old May 21, 2014 | 06:24 PM
barngal6's Avatar
Thanks, I tried it. Drained the oil, but didn't give me more leverage, limited space, so it's not off yet.
Old May 21, 2014 | 06:33 PM
barngal6's Avatar
I get a tiny budge with the channel locks, but can't get a new bite d/t space.
Below is a picture of a metal tubing that camps onto a 90' bolt. If I could unclamp that line at the and move it, I'm pretty sure I can do this.
So is it ok? I'm looking the part up but thought you might have a quick answer.x thanks for all the help
Old May 21, 2014 | 06:52 PM
barngal6's Avatar
Got it, finally. Didn't remove that line. After knocking it loose a little with the channel locks, warming back up in the sun, and the extra room, I managed it with the oil filter wrench, verrry sloooowly.
From the date on the filter, I see I must have run into the same problem with the last oil change, and skipped changing it.
Thanks for all the help. I hate paying $200+ for an oil change just because of a filter...
Old May 21, 2014 | 09:50 PM
GASKICKER's Avatar
I had a similar problem removing an oil filter from the 350 in my boat; after a few hrs trying to figure out something, even considered just lifting the engine out a neighbor suggested this tool, and it worked like a charm. http://m.napaonline.com/Tablet/parts...320_0405868280
Old May 21, 2014 | 10:19 PM
torquefan's Avatar
I have a similar tool, a strap wrench for tight filters with poor access. It's just a loop of seatbelt type material and a 1/2" drive. The tighter you turn it, the tighter it gets. Works pretty good.
Old May 22, 2014 | 08:09 AM
patdaly's Avatar
barngal, since you sparked the Alt., just make sure you are charging once you get her running. It is easy depending on how much you really hit it to blow the 140 amp fuse going into the PDC on the drivers fenderwell.
You don't want to know how I know that......
Old May 22, 2014 | 08:59 AM
Dieselbuilder's Avatar
When you put the new one on oil the gasket AND DO NOT OVER TIGHTEN to many people make that mistake and let the engine cool down its easier to come off http://contentinfo.autozone.com/znet...25320/image/4/ here is what i use
Old May 26, 2014 | 10:27 PM
joem's Avatar
I also use a belt type oil filter wrench, fits in all nice and flexible then the harder you turn the wrench the more it grabs. works great on my other ultra hard to get to filters on things I own too
Old Jun 1, 2014 | 06:42 PM
John Davison's Avatar
$200???????? I go to a place here that the owner himself works with the employees. Delo 400, filter, all fluids topped (transfer case, axles, ect), floors vacuumed, windows cleaned, tire pressures, end to end. $75. You're getting ripped off.
Also, when you put the new filter on, don't use a filter wrench. Just grab it by hand and tighten. Try to back it off by hand, if it doesn't come lose easily it's good. Makes it a lot easier next time.
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
georgia peach
Nov 5, 2004 07:13 AM
04ctd
Sep 14, 2004 04:43 PM
