oil at crack on bottom of transmission
Old Jul 21, 2005 | 05:42 AM
plow's Avatar
if there is oil making this area wet what would this mean?
Old Jul 21, 2005 | 06:53 AM
smokindog's Avatar
Where is the crack specifically? Front, rear, side? Need more info to help.
Old Jul 21, 2005 | 07:49 AM
Cowhand's Avatar
It's probably from the draft tube....wipe it off and see how fast it comes back.
If it seeps out of the little metal cover on the bottom of the bell housing after you wipe it off, it's probably the rear main seal.
You might also check #6 valve cover, sometimes they'll leak in the back and run down the trans adapter.
Old Jul 21, 2005 | 08:24 AM
plow's Avatar
its the crack at the bottom of the bell housing and #6 cylinder was leaking a couple weeks ago but i have recently changed all 6 gaskets that may be were it was coming from i will clean it off and check again.
rogerL1961
Oct 15, 2007 08:22 PM
pgm02002
Jul 16, 2007 06:01 AM
tilyn62
24
Sep 30, 2005 07:08 AM
quantrill88
23
Nov 16, 2003 07:51 PM
