Oil Analysis
Oil Analysis
I seem to remember that an oil analysis will tell you if excess brass is in the oil--excess brass as in your rod bearings are shot. Does anyone have experience with oil analysis and whether this is true?
in my opinion, an oil analysis is a waste of time and money unless something is happening in the engine that would warrant it, then a tear down would be in order!
I use blackstone analysis. Their reports are very detailed and fact based. As an example, if something is happening inside a motor with unusual high levels of " metal, byproduct or chemical" they would be able to detect it and possibly provide a resolution prior to a full mechanical failure. I look at their analysis just as you would your dash gauges, they're providing info on the internal moving parts, oil and respective wear. Hope this helps.
I use Blackstone, the sample i sent in for my 12V was to find out if any coolant was in the oil- the oil was perfect. My 2013 VW TDI however has 800PPM aluminum in every sample
Here is the link to that saga: http://forums.tdiclub.com/showthread.php?t=408249
Here is the link to that saga: High aluminum in oil analysis - TDIClub Forums
ctd4stan
05-05-2011 10:39 PM
92smokin blacky
01-25-2011 11:36 PM
Bobcat698
11-01-2005 07:05 PM
