o-ringing the head?
Old Jul 30, 2006 | 06:12 AM
possum67's Avatar
o-ringing the head?
ok i no i have a head gasket leaking anti jiz out the front pass coner of the head and its time to fix with the mods i have (my pyro gage tells me) its time for more boost i no that the head needs o-ringed when they cut the groves anound the cyl do they also make (what ever the matrial is) the ring to go in the grove? also where is the best/cheapest place to get a head gasket kit? planning on doin the deal myself just needen a little info
Old Jul 30, 2006 | 06:59 AM
frostie's Avatar
I had ATS O-ring my head. they installed the O-ring material into the groove. I believe it was .061" either copper or? not sure what material. I had them give me some extra incase I goofed something upon install.
I bought my head set through Cummins.
ATS wanted the gasket to make sure the groove was in the correct place. I used a stock gasket and the O-ring gets sandwiched against the steel ring on the gasket that goes around the cylinder.
Im only seeing 44 PSI boost at this time, however turbo upgrades are in the future.
While your at it, you may go ahead and make those 6 holes in the side of the head a little bigger and a little shineyer
I happened to have an extra 2nd gen head laying around, I ported and polished it, had a valve job done, had it surfaced, then O-ringed.
I also installed an ATS manifold too while I was at it.
Good luck
The_Head
Jun 28, 2011 09:25 PM
caleb c.
Oct 17, 2006 12:30 PM
hertz
Oct 27, 2005 08:05 PM
2whistlers
Jan 21, 2005 09:52 AM
GO 4LO
19
May 5, 2004 03:25 PM
