NV4500 fifth gear...
Old Aug 12, 2005 | 11:50 AM
GO 4LO's Avatar
Looking at buying a used '97- seller said that when he puts it into fifth, nothing happens, no grinding, no nothing, just revs freely like it's in neutral - is this the symptoms of the fifth gear nut having backed off or something more serious? What's it cost to get the fully splined shaft to repair? Thanks!
Chris
Old Aug 12, 2005 | 12:32 PM
Palmetto_kid's Avatar
Thats it. Happened to me on 2 of my 3 dodge trucks.
Old Aug 12, 2005 | 01:13 PM
apwatson50's Avatar
If the shaft/splines and gear are still in tack than it would be as cheap as a new updated nut( maybe $50) and taking the back of the tranny apart and installing it.
If the shaft/splines are not good than the entire tranny needs disasembly to replace the shaft.
Go to quad 4X4 and read about it there. Looks like a good shop and good products.
It sounds like most of the time you can just put a new updated nut on and its fine.
Old Aug 12, 2005 | 02:38 PM
CTD NUT's Avatar
Go to Quad 4x4 5th gear problems and fixes to get all the info you need and learn the RIGHT way to fix it.
Old Aug 12, 2005 | 07:57 PM
Jeremy Cusick's Avatar
Could also be the snap-ring that holds the 5th gear synchros on the shaft. BT,DT.
Cadillac Man
May 30, 2009 05:16 PM
glideslope
Nov 17, 2008 07:48 AM
aksparkey01
Mar 30, 2008 09:02 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
