NV4500 Clutch pedal Pops going in and out! (Searched)
Old Jun 10, 2009 | 11:15 AM
STate's Avatar
So I did a search and the words clutch and pop are just too broad. Has anyone found a solution to the pop from depressing the clutch pedal and again as it comes out? I put a little white silicone grease on the rod but it only helps for a few hours. Also, it seems temp. sensitive at times.
I get so frustrated with the noise...I feel stupid for letting something that small get to me.
Thanks
Scott
Old Jun 10, 2009 | 10:27 PM
Lil Dog's Avatar
Is it the boot on the clutch rod or the lock out switch making the noise?
Old Jun 11, 2009 | 08:11 AM
STate's Avatar
I want to say its the clutch rod, because if i spray the rod with silicone, it seems to subside for a bit. I dont know what the lock out switch is...please explain.
Scott
Old Jun 11, 2009 | 09:46 AM
Lil Dog's Avatar
On the rod there is a sliding switch for the starter lock out.. Maybe its the popping sound you hear???
Old Jun 11, 2009 | 10:36 AM
STate's Avatar
Ok, I see it. If that is it, what can I do about it?
Old Jun 11, 2009 | 12:25 PM
gadget.35-06's Avatar
If it's temperature-sensitive I'd be looking at the master/slave cylinder assembly; if underhood heat seems to affect it, that seems logical to me. Or, if the pressure-plate diaphragm "fingers" are uneven from slippage-induced overheat(which would take the tempering out of the diaphragm) it could cause a "pop" as a "finger" hangs up or suddenly releases from a burr on the throwout bearing face...all possibilities, and I've been known to bark up the wrong tree before; but these are possibilities that I have seen. Best of luck to you, I hope it's something simple.
rynojr4644
Mar 10, 2012 06:35 PM
VICTORY_OR_BUST
Mar 6, 2012 10:25 AM
Nick660
Nov 17, 2006 12:00 PM
berok
Apr 27, 2006 10:01 PM
Maccandy
May 16, 2004 09:25 AM
