no tach or speedo.
Old Dec 16, 2009 | 09:10 AM
98Slushbox's Avatar
no tach or speedo.
My dad just bought a 94 1ton 5 spd, and the tach and speedo doesnt work on it. The previous owner said they both quit at the same time. The grid heater isnt working either but have no idea if thats even related yet. I havent had any time to check it out yet. They swapped ecms, sensors and gauge clusters but had no luck. Anyone experience the same trouble?
Old Dec 16, 2009 | 09:14 AM
cmac's Avatar
does it charge properly? if not check the crank position sensor. if it is bad it causes a no or low charge and no tach situation.
Old Dec 16, 2009 | 10:12 AM
infidel's Avatar
If you also aren't charging it's the engine speed sensor (ESS) at the lower engine pulley.
Check that wiring to it is intact and that the gap between the sensor and pulley is about the thickness of a business card.
The ESS does wear out, may need to replace.
Old Dec 16, 2009 | 03:18 PM
patdaly's Avatar
Also make sure you have power to the ESS.
Old Dec 31, 2009 | 12:39 PM
98Slushbox's Avatar
I thought he said it was charging, but turns out it isnt. I will check the sensor and wiring. thanks everyone
Old Jan 23, 2010 | 08:55 PM
98Slushbox's Avatar
The truck is not charging either. We swapped altenators, crank pos sensor and the pcm or ecm whichever it is called on a 12v. Nothing has changed, still same problem. i checked for voltage at the cps with the truck running and there is nothing there. any ideas?
Old Jan 23, 2010 | 11:18 PM
infidel's Avatar
Bad connection or broken wire.
Old Jan 24, 2010 | 07:51 AM
cmac's Avatar
did you check all the fuses? both in the PDC (power distribution center, big fuse block under the hood) and in the side of the dash?
Old Jan 24, 2010 | 07:00 PM
infidel's Avatar
Check fuses with a meter or test light, just looking at them doesn't always work.
Old Feb 14, 2010 | 03:48 PM
98Slushbox's Avatar
Well, we finally swapped wire harnesses, but i think its too late. I think we need a new pcm. Its gettin 12v from the ign. but not getting the 5v to the cps.
royta
47
Jul 17, 2008 06:32 AM
ajohnson007
Dec 15, 2005 07:37 PM
99NVRam2500
Dec 15, 2005 05:12 PM
Crabjoe
Jun 9, 2004 05:13 AM
97CTD
Aug 14, 2003 03:31 PM
