No limited slip
Old Nov 11, 2005 | 01:53 PM
JKM's Avatar
JKM
Our 97 with D 80 has LSD, and it works good , i have had it push the front end sideways on slippery roads when only one wheel had good traction.
Old Nov 11, 2005 | 03:29 PM
CTD NUT's Avatar
Originally Posted by Eskimo
Just not a big fan of clutches on something that sees alot of miles, and is a street queen, but anything beats the 1-wheel wonder action!
So I'd wind up doing the D70 Powr-lok and drilling out the holes for the D80 ring gear bolts?
FWIW, my 94 2500 Plok has 305,000 km and has never been touched and my 98.5 3500 has 340,000 hard working km and that Plok has also never been touched. These units are not your typical clutch packed LS's with a fixed amount of preload......since the clutch preload is variable in relation to torque input the clutches last many times longer and perform MUCH better than the typical fixed preload units like the Trak-Lok.
f you cannot find a D80 Plok, you can use a D70 HD Plok and have the ring gear bolt holes slotted to accept the larger ring gear bolt circle diameter of the D80 ring gear. You CANNOT use a standard D70 carrier in a D80 as it a completely different unit that has no interchangable parts with the D70 HD or D80 unit.
Old Nov 12, 2005 | 04:33 PM
Stamey's Avatar
Since we are on this subject again, could someone please clarify something for me? Are factory LS units in the Dodge 2500 (in my case 96 and 2001.5) Powr-Loks?
BTW, the LS unit in my 96 has seen 193K hard miles and the LS unit is still tight and functional, so whatever it is, the qquality is certainly there.
Thanks,
Chris
Old Nov 23, 2005 | 05:49 PM
Stamey's Avatar
No one knows the answer to my question, huh?
Maybe this just needs a bump.
Chris
Old Nov 23, 2005 | 06:28 PM
doubleclick's Avatar
I am wondering too, my 95 has LS and is working perfectly. Which would it be?
Old Nov 23, 2005 | 10:01 PM
v8440's Avatar
I think they're traction lok. In any case, my '98 dually with a 4.10 LS D80 just spit some spider gear chunks out. I'm mostly done swapping another rearend in, but I have to say I never expected to bust a dana 80. I also hear that the factory limited slip in these isn't that strong, that some other alternatives are much stronger. Of course, a dana 80 is just so big to start with that I can't see anything in it being really weak.
Old Nov 23, 2005 | 10:20 PM
Bobcat698's Avatar
My limited slip works awesome! I've never seen only *one* tire slip.
Old Nov 23, 2005 | 10:23 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
98 is the change over year.
97 and earlier d80's have the Plok with slots for the spider gear shafts to ramp up.
98 and later came with the bolt together T-Lok, the Track lok appears similar to the Plok but the cros shaft is fixed there are no slots and the spider gears cannot ramp up and load up more load than the initial pre-load.
if you shelled out a set of spider gears in the P-lok its not uncommon it is rare but does hapen nice thing is the P-lok can be disassembled, rebuilt/repair for usually under$200-$250 in parts
clutch kit is $60, side gears $100 spider gears and shaft usually are around $75-100 depending on the vendor. Good Luck
BTW the carrier split is at 3.73 so 3.54 is one carrier 4.10 will require another
All the guts from a 35 spline - D60 Power lok, D70 Power Lok, D70HD power Lok and 1994-97 Power Lok will interchange. the cross shafts and spiders in all 4 are the same side gears and clutch packs are too.
Good Luck
Dont be fooled by the sales pitches the Plok beats the T-lok in life span, strength, afordability and rebuildability
shawn085
Nov 21, 2005 12:46 PM
dkinzer
May 23, 2005 08:57 PM
White02Sport
Apr 16, 2003 12:08 AM
NWDave
Jan 25, 2003 06:03 AM
Srigs
Nov 13, 2002 09:30 PM
