No Heat, Hard Brakes, Oil leak, Heater wont switch
check you vaccuum lines if any one pop loose you will have this same problem probably not the pump check all the connections up around the firewall between the master cylinder and the motor on my 96 i have 3 connections there and once in awhile one comes loose
Dargo
Jan 12, 2018 07:45 PM
06RAM2500
Jan 1, 2010 10:57 PM
wise_cummins
Dec 3, 2007 04:59 PM
