No Heat, Hard Brakes, Oil leak, Heater wont switch
Old Dec 1, 2007 | 07:47 PM
wise_cummins's Avatar
So I have a 90 dodge non intercooled is my vacuum pump out?????
Old Dec 1, 2007 | 08:06 PM
MoparMarv's Avatar
I don't know about these trucks but on a 240D Benz that fits a vaccum pump failure perfectly. Check your lines for breaks or disconected parts.
Old Dec 1, 2007 | 08:34 PM
97catintenn's Avatar
Sounds like it. Your truck should have the dual diaphragm style on it. The good news is that you only need one good diaphragm for proper operation, the second is more of a back up.
Check vacuum at the booster, then move on down to the pump. Check both diaphragms. If one is good and the other bad, then bypass it.
Replace bad diaphragm if you like, be ready to pay out over 100bux though.
If you don't have vacuum on either, you may need to read Jim Lane's pump rebuild thread.
Old Dec 1, 2007 | 09:14 PM
do you have a link for jim lanes thread?????
Old Dec 1, 2007 | 09:23 PM
marksmith's Avatar
Look through the sticky. Its there.
Old Dec 1, 2007 | 10:07 PM
Jim's Vacuum Pump Thread
Old Dec 3, 2007 | 04:59 PM
The Tank's Avatar
On my 90 I had the bottom vaccum pump fall OFF. The hose was holding it. Some oil leaked while driving, the breaks were hard but did not notice untill I poured oil in after an oil change and it ran out on the ground. The 4 bolts that hold it broke.
Dargo
Jan 12, 2018 07:45 PM
bkrukow
Apr 29, 2011 06:42 PM
06RAM2500
Jan 1, 2010 10:57 PM
wise_cummins
Dec 1, 2007 07:10 PM
wildcargo
Nov 29, 2005 04:20 AM
