No Bottom End?
Old Sep 28, 2006 | 09:25 AM
schaef_12's Avatar
No Bottom End?
A Few weeks ago I purchased a 98 12v ctd. The truck had already been turned up. If i mash the throttle to the ground it will not blow any black smoke until about 1700 rpm. I pulled the afc housing and found a #10 fuel plate. I tried adjusting the star wheel but it was already turned loose enough that you can barely see the star anymore. I was wondering what adjustments to make for more bottom end, can you adjust the Aneroid srew to help this?
Old Sep 28, 2006 | 09:42 AM
Clayten's Avatar
DTR's Toad Wrangler
Your governer arm is to low, adjust it to just below the tip of the j hook.
Old Sep 28, 2006 | 09:44 AM
jlipskoc's Avatar
Instr if you need them.
http://www.piersdiesel.com/TechLeverAdj.htm
Old Sep 28, 2006 | 01:04 PM
TxDiesel007's Avatar
Its exactly what im thinking
the arm is going under the plate and its causing u to feel like there is no low end power..
Rick
Old Sep 28, 2006 | 02:10 PM
schaef_12's Avatar
Thanks, I will adjust the gov. arm and hope it does the trick!
Old Sep 30, 2006 | 03:11 AM
cumminsdriver635's Avatar
Yep, your governor arm is too low. Adjust it up some or just put a 0 or 100 plate in it. That governor arm is a booger to adjust, and adjustment is not needed with the 0 or 100 plates. But if you adjust it, the 10 is a good plate.
Eric
Old Sep 30, 2006 | 10:23 AM
Clayten's Avatar
DTR's Toad Wrangler
Eric
Any blind man can adjust the governer arm. Any one that has done it can atest to that.
Old Sep 30, 2006 | 11:56 AM
Yeah, only because you cant see what you are doing
Eric
Old Sep 30, 2006 | 01:07 PM
Forrest Nearing's Avatar
also look at the end cap of the AFC housing... there's an allen headed set screw w/ a lock collar on it... back that puppy off all the way and then just barely touch the AFC shaft with it.
this setting had been messed with on my truck before I got it, and I picked up a TON of fuel between that and playing w/ the AFC washers and AFC arm
Txwelder
27
Jun 26, 2005 10:22 PM
Copenhagenjunkie
Nov 20, 2003 08:35 PM
Jambbii
Sep 4, 2003 10:45 AM
