no 1st gear no overdrive
i bleww my trans up {47rh} 9 months ago. rebuilt it.... shift kit tc and valve body. tc was slippin about 2 weeks ago. it ran fine shifted great just a little slip here n there. so i ordered a stage 5. put it in last night. went for a test drive this morn..... no 1st gear. it takes off in 2nd shifts to 3rd and no O.D.............. changed the filter and gave it a flush...... nothing changed. any suggestions?
With your listed problems the first thing i would check is for the correct governor pressures when stopped and while going up threw the gears.
sounds like you are in limp mode, if you are talking about the 97 (47re). have you checked codes? the key trick might output trans codes, been awhile since i've done it without a scan tool. if not you'll need to get the code pulled.
72demon440
04-27-2007 10:45 PM
