new seal leaking
Old Oct 27, 2011 | 02:21 PM
DC199512V87's Avatar
Unhappy new seal leaking
did my kdp and installed the new crank seal that came with the package. now its leaking a slow leak. please tell me its supposed to do that to lubricate the seal..... upon install i made sure the seal lip was all good and not peeled back or underneath anywhere and not damaged so not sure if this is supposed to happen......
Old Oct 27, 2011 | 03:30 PM
oldblues's Avatar
ua o
mine has no leak in 30,000 mi with new seal !
did u install it on a dry shaft like instructions say ?
i added a drop of loctight to the seal od when i instaled it into the cover ?
Old Oct 27, 2011 | 04:32 PM
yes installed it and the shaft totally dry like it said and used rt silicone around the od. not impressed.....
Old Oct 30, 2011 | 10:57 AM
cromulius's Avatar
I'm pretty sure its not supposed to leak. I installed mine totally dry.
Old Oct 30, 2011 | 11:37 AM
rebal's Avatar
it sould not leak at all eather you messed up or its a bad seal. Did you use the plastic install sleeve when you put it in? if yes you got a bad seal
Old Oct 31, 2011 | 10:13 AM
infidel's Avatar
Could be a groove worn into the shaft where the seal rides.
Old Oct 31, 2011 | 12:06 PM
checked for a wear groove on the shaft and didn't c any significant wear before installing the seal. musta somehow messed the seal up......
92smokin blacky
Mar 30, 2010 06:09 PM
pwrtripls1
Jan 7, 2008 08:55 PM
dieseljerk
Jul 8, 2004 07:23 AM
SSV1761982
Jun 24, 2004 11:15 AM
