new??
yook it on the highway today i could not get it over 75...now that I know its not supposed to be that slow i will start looking for the problem rather then the upgrades for now...with the gauges would i be able to now if my turbo was going bad?
You may have a throttle cable or linkage problem that can be fixed free under recall.
Go here http://www.dodge.com/webselfservice/...eenName=recall
You will need your VIN number
Get the recall and any others that haven't been performed done.
thanks for the recall info i will get on that next week...as far as the rpm I know it revs to about 2500 in neutral not sure about 75 i will try it first thing in the morning and get back on here....thanks again to everyone for there help..
If you have stock tires, you have a 3.55 rear. Not being able to do over 75 sounds about right for a 94, they would usually fall flat on their face around 2200 rpm. That sounds like your problem, as the tach isn't exactly super accurate. Having the gauges will help with trouble shooting a little, but a stock truck isn't gonna make tons of power, so you'll have to look elsewhere. Have all recalls done as stated, make sure all clamps/hoses are good, and that the intercooler isn't punctured.
After all that checks out, take your stock plate and grind to a 10, get some washers to mod the governor springs, ditch the stock air filter for a BHAF, toss the silencer ring. The plate and washer mods will really wake the truck up. Tossing the silencer ring just makes it sound cool, and the BHAF will help it breathe a little better, and seals much better.
k.this is what im gonna order ..........pyro an boost gauges gsk 3k..boost elbow and grind my plate to a 10 possably 100...first i wil have all th recalls done..and found out ihave a K&N airfilter...does this sound good or am i missing something?????
grishfish
113
Mar 3, 2013 10:53 PM
OOPS
Aug 28, 2004 07:15 PM
midwestdually
Mar 21, 2003 09:06 AM
