Need some help with fluids!
Old Apr 12, 2011 | 11:57 AM
esgdakota's Avatar
Hey guys
I have a 96 12 valve 4x4 5 speed. And I would like to change all the fluids.
so i have a couple of questions
1. What weight and kind of fluid do I need to put in the front dana 60 axle and the rear dana 80 axle?
2. What weight and kind of fluid should I put in the transfer case?
3. What weight and kind of fluid should I put in the Trans?
4. Are there any fuel filters that I should change? If so where are they?
If there isn't a fuel filter should Install one?
5. Do you guys have any tips or trick that I should know about before
I start this process?
I did a search and found several different answers for different years so I thought I would ask for my Specific truck.
Old Apr 12, 2011 | 12:10 PM
Dr. Evil's Avatar
www.dodgeram.org has a wealth of information and will answer all your questions including fluid specs and capacities
Old Apr 12, 2011 | 04:11 PM
esgdakota's Avatar
I don't see where the fluid specs are for the rears? can you point me in the right direction?
Old Apr 12, 2011 | 06:45 PM
gorms's Avatar
For differentials I have been running Lucas 75w90 for I think about 70k, change it every 20 for rear and 30 for front. No friction modifier needed with Lucas, and my LSD still works pretty good at over 200k, so it is working for me.
You didn't mention power steering, coolant, or brake fluid. All should be considered if it hasn't been done in a while. Good luck.
Old Apr 13, 2011 | 07:23 AM
Dr. Evil's Avatar
its listed right under the specs section - lots of info there you just have to look to find it.
Dana 80 - http://www.dodgeram.org/tech/specs/a...RBI_specs.html
Dana 60 - http://www.dodgeram.org/tech/specs/axle/axlespecs.html
Transfer case - http://www.dodgeram.org/tech/specs/tranfer_case.htm
fuel filters - http://www.dodgeram.org/tech/dsl/fil...uel_filter.htm
http://www.dodgeram.org/tech/dsl/fil...filt_clean.htm
Old Apr 13, 2011 | 09:38 AM
esgdakota's Avatar
Ok! Sorry i did not see it. i need to pay more attention. thanks for your help!
Old Apr 13, 2011 | 09:59 AM
infidel's Avatar
One thing you only find in the factory service manual is the Dana spec for their differentials is 3/4" below the bottom of the fill plug in the front and 1/2" below in the rear.
Most of these differentials will eventually leak out the end seals if filled to to the bottom of the hole.
Syntorq (not Syntech!) or Amsoil MTG are the only fluids proven long term.
All other fluids will eventually eat the syncros.
For the best price on the expensive Castrol Syntorq used in the NV tranny give these guys a call.
$52 including shipping for 5 quarts> http://www.blumenthalmfg.com/
Old Apr 14, 2011 | 12:05 AM
Dr. Evil's Avatar
^^^ very important points by Infidel ! ^^^
12valvin
Sep 8, 2009 03:33 PM
bigfish5
Nov 14, 2008 07:54 AM
patrick
Jul 8, 2008 07:20 PM
bsj04
Sep 20, 2007 08:09 AM
RAM123
Oct 9, 2006 03:39 PM
