My Tranny Hates 40 Miles Per Hour!!!
Old May 4, 2005 | 08:34 PM
BoatRick's Avatar
1995 3500 DRW, automatic tranny, 140,000 miles. I have only had it since last November so I can't really speak to what treatment it has had or what it did in its prior life but I pull a couple of big trailers every now and then. When I am cruising along at about 40, either with a load or not, the torque converter seems to lock and unlock. The only way to make it stop is to accelerate a little. Anyone have any idea what might be wrong.
Rick
Old May 4, 2005 | 08:42 PM
kandgo's Avatar
https://www.dieseltruckresource.com/...&highlight=tps Read thru this, does it do it when you pull it down into third? If so your tps is most likley dirty inside or out of voltage adjustment. Goodluck,,Rick
Old May 5, 2005 | 12:18 AM
BoostdCTD's Avatar
Kandgo sounds right on, this will help repositioning it upon reassembly. http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old May 5, 2005 | 07:22 AM
BoatRick's Avatar
Wow, thanks for the quick replies. They seem to be right on point. Now another question....Do you guys tow in OD, or do you turn it off?
Thanks again,
Rick
Old May 5, 2005 | 07:24 AM
Bob Berends's Avatar
Tow in OD if the rpm is above 1750. This is my rule of thumb for all OD conditions. It helps the trans get proper oil flow.
LaserBob
Old May 5, 2005 | 09:39 AM
infidel's Avatar
If you want your tranny to last, towing or not, turn the OD off till you're going over 55.
Old May 5, 2005 | 11:07 PM
kandgo's Avatar
There was a thread somewhere were you could rewire the OD button to stay off till you need it. I was going to do it to my 94 auto and then I got a 5spd, I think it would be nice to have it that way. Goodluck,,Rick
Old May 6, 2005 | 12:49 PM
infidel's Avatar
Here's how to change the switch so OD is off on startup
http://dodgeram.org/tech/mods/transm..._inverter.html
Old May 6, 2005 | 08:56 PM
kandgo's Avatar
Thanks Bill, I bookmarked that one, I need to do it for a friends truck,Goodluck,,Rick
Old May 9, 2005 | 06:50 AM
BoatRick's Avatar
The comment about leaving the overdrive off until you go over 50 is interesting. I will try it the next time I drive the truck. I read alot about putting in a switch for manually locking the torque converter. Other than some transmission breaking I was wonder what benefit you would get from this versus just letting the transmission do it automatically?
Thanks again for everyone's quick answers, this forum is great a place.
Rick
Old May 9, 2005 | 09:17 AM
infidel's Avatar
You can let it do it automatically, I usually do but where I live the stoplights are fifty miles apart and speed limit between them is 70.
If you're driving in city stop and go lock OD out.
Old May 9, 2005 | 11:22 PM
mr T's Avatar
ur obviously never locking out OD ...if ur going 40 mph in 4th then ur luggin around and ur tranny cant make up its mind....just lock OD out and stay in 3rd gear till ur on the freeway
leeboy
Jan 18, 2011 08:21 PM
Rednecktastic
Nov 7, 2007 12:27 PM
bekim
31
Nov 22, 2006 05:32 PM
walexa
Sep 7, 2005 11:40 PM
