My CAD locks/unlocks front end
Old May 22, 2010 | 11:13 PM
manureman's Avatar
Been having a problem with the CAD locking and unlocking my front end while I drive. It produces a loud thud and usually does it when I slow down, or start going up a fill. I've replaces the vacuum motor and the vacuum switch on the transfer case. Any other ideas why this is happening?
Old May 23, 2010 | 07:09 AM
J Lent's Avatar
Mine was doing the same thing, turned out to be a vacuum line had a hole.
Old May 23, 2010 | 09:22 AM
blackimpala's Avatar
You don't say what truck you have but my 96 has a vacuum switch on the transfer case, you might check if yours is shifting on its own.
Floyd
Old May 23, 2010 | 03:27 PM
manureman's Avatar
I just checked and I am getting 10 inches of vacuum. Must be in the transfer case where it' doing it?
Old May 23, 2010 | 05:17 PM
J Lent's Avatar
You sure you didn't cross 2 vacuum lines when replacing the parts?
Old May 23, 2010 | 06:26 PM
manureman's Avatar
No,
I checked them both out and they're both fine. Just took the front driveshaft off, and took the truck for a drive. It's still dong it. Almost sounds like it's coming from the transfer case.
Old May 24, 2010 | 06:34 AM
Hodge's Avatar
Have you disconnected the vacuum lines to the CAD, and driven it? See if it still does it, which would isolate it to the TC, or if it doesn't do it, you know it's in the CAD.
Old May 25, 2010 | 09:34 AM
duster75's Avatar
mine was doing same 2 winters ago turned out to be cad. after replacing vac switch first. Nate
Old May 27, 2010 | 04:33 PM
TxDiesel007's Avatar
for all those with 4x4 problems
i assure you, posilock your ride and FORGET ABOUT IT....
no more issues with 4x4, and install is cake... plus a cool 2 low function...
win win situation
Rick
307Kenworth
May 14, 2011 08:30 AM
Gear Poet
Aug 14, 2009 11:12 PM
racinrex
Nov 19, 2007 03:28 PM
95black2615
Aug 21, 2005 08:46 PM
silverram323
Nov 13, 2003 05:55 PM
