Mechanic Recommendation for Omaha
Old Jun 6, 2006 | 12:05 PM
95_12V's Avatar
Exclamation Mechanic Recommendation for Omaha
I have a 95' 12V 2x4 that needs some work done and haven't found a good shop yet! Recommendations? (I just moved here)
1) The front suspension needs to be corrected (pulling hard to the right),
2) I've had intermittant transmission problems (auto) after replacing it this past Feb.
3) There's a small leak on the fuel return line going into the sender unit. (I might replace this myself)
Old Jun 6, 2006 | 03:26 PM
marine4life's Avatar
I lived in Omaha till about 3 years ago. As diesel shops go, there are not very many good ones I know off. I know in Lousiville and Waterloo there are some good small town shops. What are you trying to fix, most of the problems with a 12v engine can be solved by your run of the mill back yard mechanic. Send me a pm with any questions. Most of us dodge owners will tell you they almost always pull to the right. If you look up the trac bar problem there should be proper alignment settings somewhere in those posts. Make sure you have the shop set them to those correct settings though.
schu777
Sep 10, 2009 08:50 AM
svanni
18
Jul 23, 2007 10:09 AM
clemsontiger
May 6, 2005 03:18 AM
PeteRR
Mar 24, 2005 06:52 PM
