major emissions problems - please help!
Originally Posted by arroyojim
thanks,
this test, as far as i can tell, only tests opacity. not sure the relation of NOX to opacity. i know running bio-d causes slighly higher NOX, but this is a major increase in opacity which was not present when i started running bio-d about a year ago. not positive, but i don't think NOX affects opacity?
Less opacity from advanced timing produces more NOx
More opacity from retarded timing produces less NOx.
You need a timing check AND a pressure test on the charge air side.
A few more checks:
Boost line to the turbo wastegate is open.
Blown wastegate
Just curious. Why are you checking the emitions anyway? Also your truck shouldnt have a cat. The only time our stock 98 12v's smoked is when you mashed the pedel in 3rd and somewhere above 2300rpm it would put out a little bit. nothing major though. However when I rolled the starwheel forword it smoked quite a bit more. Have you checked to make sure its back?
thanks for the info guys. i was wondering about the cat. converter. my manual doesn't list it under emissions controls, but i have heard people talking about theirs getting plugged up:
"Check first for a plugged catalytic converter , fuel filter, or air filter
o From: DYNOOMAN@aol.com - I see alot of low horsepower problems due to Excessive idle time's and plugged cat's... About 50%"
from dodgeram.org.
i will try to check out the boost line and wastegate. i also read that the afc spring could be at fault. is that related to the starwheel? i only have one of those Haynes manuals and can't find a section describing the interior of the afc.
btw, infidel is right about emissions tests being required for where i live here in the Front Range
from dodgeram.org.
If your truck is truly stock, the AFC spring, housing position, and star wheel shouldn't be the issue.
Retarded timing and boost leaks are the most common problem associated to a stock truck with emissions problems.
A sooted cat does cause smoke, but you can usually clear that with loading the engine such as a hard run up a mountain pass
Most boost leaks are hard to find without a pressure test on the charge air side.
94dodgeman
57
May 17, 2015 09:19 AM
oberon1974
17
Jan 15, 2011 11:15 AM
pickupman96
Jul 22, 2008 05:49 PM
juice
Jul 10, 2006 05:43 PM
