low boost, high egts?
Old May 1, 2005 | 06:32 PM
stoneman's Avatar
Cant get boost over 10psi and my egt reaches 1100-1200 going down the hiway @ 70mph on cruise.
From dead stop,I floor the pedal. Egts hit 1100-1200 and boost under 10psi ***?
Old May 1, 2005 | 07:25 PM
MnTom's Avatar
You need to start looking for boost leaks. The most common is for the boots to come loose and leak. Check all four closely, especialy the lower one on the passengers side. That one sometimes expands enough to contact the inner fender and wear a hole in it. If you don't find a leak then start the truck and spray the whole intake system with soapy water, including the inter cooler. You should see bubbles where the leak is.
Tom
Old May 1, 2005 | 10:57 PM
infidel's Avatar
If you can't find leaks the next step is to check if your timing has slipped.
Old May 2, 2005 | 08:08 AM
stoneman's Avatar
Thanks for the advice. I will check all this out and report back.
Old May 2, 2005 | 03:23 PM
Richard William's Avatar
I had this problem with my '94 and my wastegate actuator was blown out.
Old May 2, 2005 | 03:53 PM
phox_mulder's Avatar
Catalytic Converter.
Probably clogged up, restricting exhaust flow which decreases boost and raises EGT.
phox
Old May 3, 2005 | 03:55 PM
MnTom's Avatar
phox
YEA!!!! I forgot about that one. It happened to me!!!!
crewcabxlt
Jun 18, 2009 01:15 PM
lgp9999
Sep 8, 2007 11:19 PM
GaryGus
Nov 19, 2004 06:10 PM
BCarmicle
Sep 22, 2004 12:10 PM
cowpie
Jan 29, 2003 09:08 PM
