lock up convertor
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
but i wouldnt recommend it on a stock transmission.
i just did my tranny about 3 months and put billet input shaft t/c strait cut overdrive planetteries in and messed with the valve body to get rid of some shift over lap do u think that will handle it and why do you say not to do this on a stock tranny my 97 is stock and i would like to put this switch on it
You can put it on your stock trans. I have had one on mine for about 8 years and it is the original trans. 230000 miles. It is now showing signs of needing rebuilt. I believe it is mostly the converter. I do not attribute the need of repair to use of the lock up switch. I would say it has prolonged the life of the trans. It all depends on how you use it. You should not shift the trans., under load, with the switch locked. I could see where you could do some real damage under full pedal. When I take off I turn my OD off and lock the converter when it shifts ,on it's own, to D. I get to the speed I want in D, then I will leave it locked up and flip the OD switch to let it go into OD while locked with the switch. I just let off the pedal almost completely during the shift. Once it shifts I roll back on the pedal and it is as smooth a shift as you could want. Once you get the timing down with that you lose almost no momentum. I have hated the way this truck shifts from the day I bought it 10 years ago. Thanks to the people on here I have learned to make it shift the way I want it to. The lock up switch has also saved my brakes as I can leave it locked in D while going downhill and not have to use my brakes near as much as with the converter unlocked. Without the switch the truck pretty much freewheels downhill and I was on the brakes all the way to the bottom.
If you use it right the switch is an asset to any truck with an auto trans.
With a '96 you may have to have the dealer flash the computer for a lockup to work.
Earlier '96s had some of the programing for the older RH transmissions, causes the lockup switch to not work right.
'96 have a RE tranny. Flash costs about $80.
I think I remember reading some have wired the switch with a relay through the brake switch, thus, stepping on the brake will unlock the TC. Can anyone confirm this? I don't have the lock-up switch but have been thinking about putting one on.
Floyd
Floyd
I believe I read about this as well, using the brake pedal to unlock the converter switch. I didn't do it because I thought I would still use the brake going downhill and everytime I did it would unlock the converter. I like the switch better. It stays locked going downhill no matter how many times I step on the brakes.
I read that someone had used a hobbs switch in one of the test ports of the transmission, with a set of relays, that would kick out the lockup if you forgot to manually unlock it.
I haven't found a full description on it. Any one know where it is?
This is the closest I have found, but not the hobbs switch one. I figured I could possibly work the switch in, but a already diy thread would save me some time.....
Floyd
71_340
Mar 12, 2007 08:27 PM
0425004x4
Feb 16, 2006 07:16 AM
