Leaking seal 97 CTD 4x4
Old Feb 1, 2006 | 05:34 AM
wpm's Avatar
wpm
I have two problems with my 97 Dodge 2500 CTD.
How serious a problem is a leaking rear pinion seal and a leaking transfer case seal?
Are these expensive fixes?
Old Feb 1, 2006 | 08:16 AM
big jimmy's Avatar
I know the tranfer case seal is an easy fix- remove the skid plate and front axle. Then the seal.
Big Jimmy
Old Feb 1, 2006 | 02:49 PM
Mr. Jimmy's Avatar
Both are easy fixes. You need a service manual if you don't already have one.
Old Feb 1, 2006 | 03:35 PM
rattlerbob5.9's Avatar
easy fix made easyer
Big Jimmy they would both be even easyer fixes if he left the front axle in place and only removed the drive shaft
Old Feb 1, 2006 | 08:54 PM
big jimmy's Avatar
Good thing I'm not in politics....my career would be over! I meant drive shaft, not the axle as that Big Jimmy guy said... (who is that guy anyway??)
Big Jimmy
Old Feb 2, 2006 | 11:28 AM
Lil Dog's Avatar
If you have a rear pinion seal leak, you may need to look at the rear end as well. Typically the seals only go if there is bearing clearance and not enough pre-load on the pinion bearings. You might replace the seal and in 4-5 months will have to do it again. If you are doing the pinion seal, take the rear pan off the diff and take a look at the gears, oil etc for wear or wear metal in the bottom. You need to shim the pinion assembly for proper pre-load so its not as easy as making the nut tighter.
Old Feb 2, 2006 | 02:38 PM
Ocmechanx's Avatar
If its the rear axle and the rear seal on the T-case I'd check the carrier bearin on the driveshaft while ur at it.
Bryan
pwrtripls1
Jan 7, 2008 08:55 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
dieseljerk
Jul 8, 2004 07:23 AM
SSV1761982
Jun 24, 2004 11:15 AM
