was leaking now not? i dont get it
Old Aug 28, 2008 | 08:49 PM
ahopper's Avatar
I walked outside today and found about what looked like about a quart of coolant on the ground. got up and under ther and it looked like it was coming from the bottom of the radiator on the dirver side were the plastic tank conects to the metal core. i filled my coolant tank back up and havnt leaked scince then. any ideas?
Old Aug 28, 2008 | 10:51 PM
dozer12216's Avatar
Like a bad dog won't come back an bite you. Probablly the tank to tubes connections / gasket is weak. High pressure after shut down forced unsealing. Next time pressure goes high the leak will return. With age you might look for rad assy and be done with. Some good aftermarket pieces are avalaible and save a ton of money. Look on internet.
Old Aug 29, 2008 | 11:16 AM
Baja's Avatar
Mine did the same thing, but over time it got worse to the point of replacement. Leaks rarely fix themselves.
Apparently there is a radiator site that sells a repair kit for the side saddle tank seam to the main body. I have read of others on this site who have used it with success. Might be worth checking out.
Old Aug 29, 2008 | 04:02 PM
ahopper's Avatar
it did the same exact thing again to me today.leaked in the morning now it isnt. im gonna try to make the 150 mile trip to phoenix where i have acces to tools and such. i put some stop leak in it. hopfully it will hold. also will pick up a new radiator while im down there in phoenix. chepest i have found is $259 at napa. does anyone have a cheaper idea besides the internet bc it wont get there in time?
Old Aug 29, 2008 | 04:07 PM
Baja's Avatar
I would remove the cap, no pressure to blow the leak should it become weak. Mostly downhill anyway, some good climbs though. Good luck
Old Aug 29, 2008 | 10:44 PM
oldblues's Avatar
hi
i had the same prob with my 98 12v .
it had a signifigant leak !
put in a bottle of bars leak , the kind that looks like alluminum filings in a liquid , slowe up right away and eventualy sealed compleatly !
has not leaked in almost 1 year !
it worked for me !
Old Aug 30, 2008 | 01:25 PM
ahopper's Avatar
made it back with no leaks1 looks like i might have a samall drip. still worrys me so i will be replaceing it today anyone know where i can get the best priced one? Thanks
Old Aug 30, 2008 | 03:49 PM
Baja's Avatar
I have not bought from them yet, but I was leaning hard to National Cooling products, 1-800-375-7777. They have a distribution center located in Calif, but pretty close to Flagstaff.
CDoskocil9
Feb 2, 2007 11:14 PM
PourinDiesel
Nov 20, 2006 03:16 PM
the496rocket
25
Nov 13, 2006 03:56 PM
the496rocket
20
Nov 1, 2006 10:51 PM
mytrucksaslug
Nov 2, 2004 07:02 AM
