Leaking Injectors?
Old Jul 10, 2005 | 09:42 PM
Stamey's Avatar
Question Leaking Injectors?
My 96 has 188K on it and has never had the injectors messed with, as far as I know. I have not touched them since I bought the truck, about 3 months ago. After pressure washing the grime off the valve covers and top of the engine, I noticed what seems like fuel leaking from someplace around 5 and 6 injectors. It's not bad, but wet around them. The truck runs great.
Is there anything that normally fails in this area that I need to replace, washer, O-ring, etc.?
Or do I have a bigger problem to investigate?
Thanks,
Chris
Old Jul 10, 2005 | 10:03 PM
xtrm4xjp's Avatar
maybe check the return lines, bolts and seals on each injector. I have seen the lines get rusted out before.
Old Jul 10, 2005 | 10:16 PM
Sidewinder's Avatar
My '95 was leaking from the injectors. I took them out and replaced the copper washers that go between the bottom of the injector and the head and re-torqued the injectors. No more leak! I replaced thr copper gaskets on the return line while I had everything apart.
lilsuzuki4x4
Sep 1, 2011 01:50 AM
KRB
May 20, 2007 06:20 PM
CRXsi
Jul 26, 2004 07:03 AM
BIGOKIE
Jul 21, 2004 05:53 PM
Sidewinder
May 1, 2004 09:48 PM
