killed kdp this weekend!
Old Nov 27, 2003 | 11:23 PM
  #31
Dr. Evil's Avatar
Re:killed kdp this weekend!
[quote author=jrs_dodge_diesel link=board=16;threadid=22760;start=15#msg215004 date=1069975014]
Could you just JB weld the pin back in place? Its cheap and sounds like it would work.
[/quote]
I think it would be better to pound the pin back in (if it has moved), use some wicking loctite (the green stuff) and peen the head of the KDP before installing the tab....that way it will not move again.
Old Nov 27, 2003 | 11:41 PM
  #32
jrs_dodge_diesel's Avatar
[quote author=Dr. Evil link=board=16;threadid=22760;start=30#msg215131 date=1069997020]
[/quote]
Dr. Evil, I meant pound the pin back in its hole and JB weld over it and not bother with the tab. Could it be done like that?
Old Nov 27, 2003 | 11:46 PM
  #33
Dr. Evil's Avatar
I suppose...Ive never used JB weld much....as long as its good with aluminum, that should be ok...personally, Id just fab up a plate and use the accepted tab method.
Old Nov 28, 2003 | 01:00 AM
  #34
NAIL BENDER's Avatar
[quote author=jrs_dodge_diesel link=board=16;threadid=22760;start=30#msg215143 date=1069998114]
[/quote]
[/quote]
The kit is cheap at 50.00, why risk the JB WELD fix?
Old Nov 28, 2003 | 08:48 AM
  #35
I am a cheapskate sometimes. 8) It was just an idea that I thought would work.
Old Dec 1, 2003 | 10:54 PM
  #36
Barney's Avatar
Dave Fritz has some KDP instructions and a sketch of a tab here:
http://dodgeram.org/tech/dsl/Dowel_Pin/tab.htm
Old Dec 2, 2003 | 04:51 PM
  #37
Farmer's Avatar
Just did my KDP today, it went good, my pin was out about 3/16" Pounded it back in put the Cummins tab on it, it seemed a little flimsy but I can't see the pin ever pushing out and bending the tab far enough for the pin to come out again.
Now I can quit thinking about it every time I drive somwhere.
Don
Old Dec 2, 2003 | 11:06 PM
  #38
kandgo's Avatar
Good deal on the repair and peace of mind, it was not that hard was it?? Now tell all that you run across about it.Goodluck Rick
Old Jun 21, 2004 | 01:07 PM
  #39
MasseyMan1089's Avatar
Ok. So basically this "tab" is just something that goes under the bolt next to the hole of kdp and covers it. So you could take a washer and maybe braise a thin metal strip onto the side of it, and bolt it down over top of the hole? I am still kind of comfused.
Old Jun 21, 2004 | 05:21 PM
  #40
Sure, any way you can secure it is fine. A lot of guys have trimmed a fender washer or cut their own tab out of sheet metal. The official Cummins fix is to stake the pin in with a punch, that seems to work as long as you're enthusiastic with the hammer.
Smokin96_12v
Oct 12, 2009 07:39 AM
RyeThomas
Jul 11, 2007 04:31 PM
Red3quarter
May 30, 2006 05:00 PM
CUMMINSBILL
Jun 6, 2003 10:02 AM
gofastman
Mar 19, 2003 10:29 AM
