KDP question
Old Jan 16, 2007 | 06:14 AM
atthepark's Avatar
KDP question
I am getting ready to tab my KDP and am going to loctite the 5 timing case bolts while I have it open. When I turn the engine with the barring tool, does it matter which direction I turn the engine? I know I will need to turn it some to get to the two bolts behind one of the center gear wheels.
Any help is always appreciated.
Old Jan 16, 2007 | 07:59 AM
TIMMY22's Avatar
no, just turn the engine over so you can get your socket on the bolt through th windows in the gear.
Old Jan 16, 2007 | 12:12 PM
Scramblinman's Avatar
Hell, I didn't even use a barring tool when I did mine.
Old Jan 16, 2007 | 12:25 PM
atthepark's Avatar
Thanks for the help!
Old Jan 16, 2007 | 12:26 PM
John Faughn's Avatar
I would turn the eng. over in the direction that it runs , with some time and miles on it , theres going to be some slack in grears & chain , so timing can be a little off .
If you want lock tight , then remember when you take apart next time to heat if you use the red .
Old Jan 16, 2007 | 12:28 PM
Is there really a chain somewhere in the motor?
Old Jan 16, 2007 | 12:37 PM
displacedtexan's Avatar
No, all gear driven...
Old Jan 16, 2007 | 01:14 PM
I get caught with the generic replys .
Old Jan 16, 2007 | 01:20 PM
And you have been around long enough to know that someone on here will catch it
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
Deereguy
Feb 12, 2004 06:44 PM
turfquip
Nov 12, 2003 10:49 AM
1320
Jul 6, 2003 03:41 PM
