KDP and pump timing
Old Apr 2, 2006 | 04:31 PM
skbowman's Avatar
KDP and pump timing
'94 4x2 3500 auto Tow truck 105k on clock. Talked boss into the KDP kit from TST. Is it any more convenient to check pump timing with timing cover off? Timing needs to be at least checked. Don't want to over power tranny, but I would like to at least not lose speed up grades with car/truck in tow. Any advice would be apreciated.
Old Apr 2, 2006 | 06:34 PM
marine4life's Avatar
having the timing cover off doesn't really help all that much, but since your in there, you might as well check it.
Old Apr 2, 2006 | 06:42 PM
dd5.9's Avatar
there is NO reason to take the cover off! there is an alignment pin behind injector pump, have someone push it in while you crank the engine over(with a socket on crank NOT STARTER!)
Old Apr 2, 2006 | 06:53 PM
yes, there is an alignment pin, but he was talking about doing the kdp, and doing this will require the removal of the timing cover.
Old Apr 2, 2006 | 07:55 PM
infidel's Avatar
It won't make any difference if the cover is on or not to check the timing but will make it a hair bit easier if you want to change the timing.
You will need a few special tools that you don't have to change the timing.
Instructions> http://dodgeram.info/tsb/1994/18-10-94a.htm
Bumping the timing up to 16 won't trash the tranny any sooner, very little hp gain, just a smoother running engine that gets better mpgs.
Old May 3, 2006 | 05:46 PM
skbowman's Avatar
Performed the KDP kit install from TST and the kdp was exactly like the picture in the instructions. Punched it back about a quarter inch and finished the job off. I did find it much easier with radiator removed, then I could get my 1/2 inch impact in there for the crank pulley bolts. All said and done in 3.5 hours . Thanks for the help. DTR rules.......................
sootnsmoke
Jan 5, 2012 08:55 PM
guhfluh
23
Mar 3, 2010 08:44 AM
Smokin96_12v
Oct 12, 2009 07:39 AM
GR40RCapri
Jun 25, 2006 12:53 AM
wyomingpower
Apr 12, 2006 09:42 AM
