4wd light on
Old May 3, 2006 | 08:32 AM
lsc2003's Avatar
4wd light on
Hello i have a ram3500 4x4 automatic and the 4x4 light on the dash keeps going on and off. sometimes it stays on for a few minutes sometimes it blinks on and off. i noticed it blinks off and on when i come to a stop and start back moving. does this mean that i'm low on fluid. Iv'e checked the trans fluid and seems ok. any help would be apreciated thanks.
Old May 3, 2006 | 08:33 AM
TxDiesel007's Avatar
Hmmm
do you have the stock OEM vacum system? IE what year is your truck? Im supposing in the 12V forum its 94-98, but if it gets stuck, you might wanna check the little electrical connectors at the bottom where the axle connects to the vaccum lines, perhaps one of them is grounding out and causing your 4WD indicatior to come on...
Rick
Old May 3, 2006 | 11:00 AM
lsc2003's Avatar
it's a 1997 I pressure washed all under the truck maybe I knocked something loose I will check thanks.
Old May 3, 2006 | 09:23 PM
Sidewinder's Avatar
Mine used to do that too. The problem was the wireing harness that runs to the 4X4 switch on the front axle. Check the wires carefully. Mine were rubbing together so I needed to replace the wires from the switch to the first connector near the bumper.
p0wd3rp1l0t
Jun 27, 2012 10:29 PM
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
