Kdp?!?!?!?
Old Apr 3, 2010 | 11:26 PM
Ken Collins's Avatar
Kdp?!?!?!?
ok so i found out the KGP was the cause of my oil leak but anyway i was wondering if that could have caused my truck to start satarting funny not to sure so i thought i would ask you guys
Old Apr 4, 2010 | 08:59 PM
jnicewan's Avatar
I doubt it, we might need a little more detail to your starting problem. I.E. hot, cold, sitting overnight etc... Most starting problems are usually from air intrusion into the fuel system, or shut-off valve concern.
Old Apr 4, 2010 | 09:26 PM
the truck starts funny hot or cold it starts faster when its warmer but still not like it use to
Last edited by Ken Collins; Apr 4, 2010 at 09:26 PM. Reason: and it takes long to start overnight to
Old Apr 4, 2010 | 09:59 PM
cmac's Avatar
a better description of what your truck is doing, details, will go along way to people helping out with your problem. a truck "starting funny" means different things to different people. is it turning over slow? or does it crank over for a long time before it fires?
Old Apr 4, 2010 | 11:13 PM
ok well it is cranking slow thats pretty much the problem once it starts it fine but its cranking wayyyy slow and it just started ovewr a weeks time and just started getting worse and worse
Old Apr 4, 2010 | 11:46 PM
lgp9999's Avatar
Cranking slow typically is battery related
Old Apr 5, 2010 | 12:06 AM
rebal's Avatar
could just be the starter going out also lock tight all the bolts too when fixin the KDP
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
gofastman
Mar 19, 2003 10:29 AM
