KDP
Re:KDP
Most seem to happen around the 100,000 mile mark. Like anything like this, it is really a "bell curve". There is always some that happen at very low mileage, like 20,000 km and some up around 300,000 + miles. There was a poll on "that other Dodge diesel site", and it indicated almost 15% failure rate so it is a very serious fault, that neither Cummins or Dodge(DC) have taken responsibility for. Too bad "safety" was not involved ,as those faults are always corrected quickly and without question. This problem costs BIG labour $$ to fix. By the way, that poll on the other site suddenly "disappeared without explanation" about 2 months ago, which makes you wonder about the background conversations (and legal threats) with DC.
Re:KDP
Remember though, that 15% failure rate is only counting people who frequent that website, or friends of friends.<br><br>If you figure only 30% of all the Cummins owners know of that website, that 15% goes way down.<br><br>And, most of the website surfers are turning up their trucks, which might contribute a bit to the KDP coming out.<br><br>I'm not saying that it isn't a problem, just not the huge problem it is made out to be.<br><br>There are plenty owners out there that have no idea it even exists and haven't had a problem with it.<br><br>It's something to be aware of, but not something worth losing sleep over.<br>Kind of like the lift pumps in the 24 valve engines.<br>Hundreds of thousands of them never have a problem, but you sure hear of the few hundred or thousand that do.<br><br>My .02<br><br>phox
Re:KDP
Trucks at the shop as I type this getting the KDP tabed.<br><br>I go to pick it up in about an hour. (From the time I make this post).<br><br>Sure is good to know that its taken care of.<br><br>Rich.
Re:KDP
Yep, definite bell curve. Ususally higher mileage, but I did one a couple of weeks ago with 40K on it and it was out about 3/8ths of an inch.<br><br>Bottom line. Fix it before it fixes you!!!
Re:KDP
Heres one for you. <br>As I mentioned earlier in this thread, I had my truck in the shop to get the pin tabbed.<br>Well, after getting the gear case off, we could see that the pin had moved no more than 1/16 to 1/32 of an inch. <br>The pin was tapped securely in place and the Cummins tab was installed to keep it there.<br><br>So, I figured I just paid $400.00 for the security of knowing that it will never fall out.<br>Works for me. $$$ well spent!<br><br>Rich
Re:KDP
I only just tabbed mine last week and it was out 3/16" at most. I was surprised how easily it tapped back in and that the adjacent housing bolt was so loose. Mileage was only 74,000 km which is about 46,000 miles. I kind of think it has more to do with extent and frequency of heating cooling cycles since the housing is aluminum, block is cast iron and the pin is hardened steel - different coefficients of expansion. I do not know how tight the fit is with the aluminum housing though. I loctited the pin and tabbed it with loctite on the bolt also. I feel more confident taking it on the logging roads up in the bush now.
Re:KDP
I did mine a few months ago. I was pleasantly surprised at how easy working on this truck is. It was very straight forward. making a functional tab was the most difficult part.<br>My pin was actually sort of recessed, still. 123,000 miles.<br>Truck is running like a top, knock on wood.<br>I replaced my muffler and tail pipe. Rip Rook did me solid. Great fellow to work with.<br>No complaints with this truck.
Re:KDP
OK, I have 208,000 miles on my truck and have not had this problem. I hit bumps like crazy(in NYC) and average 70-75 MPH on highway. However, I really want to look at it though to make sure(Just in case). My mechanic just had the front engine cover off awhile back to fix an oil leak (seal). He said every bolt was tight, but I don't know if the KDp was checked.<br><br>Now hear me out; I am not a mechanic. In fact never did any big job, but love my tools. I change the oil and greese the joints, and stuff like that.<br><br>Can I look at this myself? Is there any way someone can give me a detailed instruction on how to look for this? I know I take off fan hub and all that stuff. <br><br>The thing I'm worried about is putting everything back together after.
Re:KDP
Now hear me out; I am not a mechanic. In fact never did any big job, but love my tools. I change the oil and greese the joints, and stuff like that.<br>Can I look at this myself? Is there any way someone can give me a detailed instruction on how to look for this? I know I take off fan hub and all that stuff. <br>The thing I'm worried about is putting everything back together after.
sootnsmoke
Jan 5, 2012 08:55 PM
