just lost 5th gear!!!!
Old Apr 15, 2009 | 07:20 PM
p.o.s.'s Avatar
driving down the highway today in 5th gear about 60mph my truck just lost 5th like i was in neutral now it goes into 5th without even stepping on the clutch..... i see its time for a rebuild but what happened?
Old Apr 15, 2009 | 08:20 PM
rstrucks's Avatar
The nut holding 5th gear on has come loose. You may not even need a rebuild. I suggest a little bit of searching as this has been covered many, many times.
Old Apr 15, 2009 | 09:53 PM
rich's Avatar
not too hard to fix lots of post here on how to fix it
Old Apr 15, 2009 | 10:05 PM
p.o.s.'s Avatar
sweet thanks guys ive been building jeeps for years and always get ragged on for not searching the forums before asking sorry guys
Old Apr 15, 2009 | 10:16 PM
Farmall Power's Avatar
Put on the chrysler up date nut with set screws, lots of loc-tite and get the welder out and put a few tac welds on the nut and shaft, did my uncles at 150k, he has 340k on it now, did my 97 last year...........
Old Apr 15, 2009 | 10:26 PM
67HotRod's Avatar
I second that fix!
Old Apr 16, 2009 | 08:26 AM
12ValverDave's Avatar
I got a NV4500 from a 2002, its getting ready to go in my truck, i was told it has the updated nut on it? I see no set screws on the nut, should i just tack weld it to the shaft?
Dave
Old Apr 16, 2009 | 11:16 AM
p.o.s.'s Avatar
i just ordered the nut with set screws and locktite im either gonna weld it as well or put the old nut on as well behind it.....
Old Apr 18, 2009 | 03:58 PM
fschiola's Avatar
Dave
Is there some way to tell if you have a splined shaft ? I thought that it was the fix for this problem.
Old May 2, 2009 | 08:22 PM
whiskers's Avatar
I've been through this 3 times. The dodge nut fix is crap. Best fix is a heliarc weld all the way around the nut. Can be done in the truck. Only need to pull off the tail shaft housing, drive shaft , etc.. The tail shafts are an aloy steel. Best to weld them with 308 stainless wire with TIG. An afternoon fix.
LemonDodge
Sep 7, 2019 03:51 PM
steveb
22
Dec 26, 2011 01:43 PM
TheNeckasaurus
17
Dec 13, 2011 08:46 PM
HemiDave
16
Sep 25, 2011 07:30 PM
LemonDodge
Sep 16, 2010 07:33 AM
