Intercooler line came off
Old Jul 29, 2003 | 06:46 PM
ridofpwrstroke's Avatar
My friend has a 98 12 valve and while driving down to go fishing, his intercooler line came off his turbo going to the intercooler. He lost a whole bunch of power. When we stopped he had oil all over the motor. We put it back on, tightened it up and it doesnt leak anymore. Did this hurt anything? Where did the oil come from?
Old Jul 29, 2003 | 07:15 PM
Mostwanted's Avatar
Re:Intercooler line came off
should'nt of hurt anything, not shure where the oil came from tho ???
Old Aug 6, 2003 | 08:53 PM
cummingetit's Avatar
He's having turbo blow-by. This is not good. He may want to look at a new turbo.
Old Aug 7, 2003 | 10:58 AM
We put it back on and it runs better than ever. We were thinking that it was hot because the turbo was doing nothing. Do you think he still is shooting oil? He ran it at least 40 miles with it off. There was oil everywhere under the hood. Now that the line is back on, there is no oil leaking anywhere.
Old Aug 7, 2003 | 11:02 AM
Mexstan's Avatar
What is his oil consumption in 1000 miles?
Old Aug 7, 2003 | 11:04 AM
I will have to ask him tomorrow. He is a kind of guy who will check it at oil changes. I will see if he used any since the last one.
Old Aug 7, 2003 | 05:23 PM
J.R. Adkins's Avatar
If the oil was coming from the charge air line then the turbo needs to be rebuilt. When you blow a boot you overspool the turbo. Oil coming out of the discharge side of the turbo is NOT good and is possibly dangerous. Check the end play and side to side play on the turbo.
J.R.
Old Aug 7, 2003 | 05:42 PM
Would oil flow more if it was hot? He was working the truck when the line came off. Will the turbo get messed up if the charge line is off because of the heat?
Old Aug 7, 2003 | 05:46 PM
There should NEVER be any oil coming out of the discharge pipe from the turbo. Only the oil drain back tube.
J.R.
Old Aug 7, 2003 | 05:54 PM
I dont know if oil came out of the outlet? All I know is that the line came off and oil was everywhere. We figured that since the line was off that oil came out of the hose.
Old Aug 7, 2003 | 06:23 PM
SolidJunkMM's Avatar
Would this cause any change in the sound of the turbo? Not at speed only at idle? My truck has picked up a strage sound that I am having trouble locating. I too recently had an intercooler line problem and wonder if it is related to the noise.
Old Aug 9, 2003 | 10:38 PM
1dslram's Avatar
Pull the hose off clean the impeller and run a few miles if there is any sign of oil STOP and replace or rebuild the turbo. If no sign of oil run about 50 mi and check again. You most likely belw out the seal and the leaking won't stop and could cause a blow up of the turbo and the cleanup of the intercooler is at least $300-$500 if you remove it and reinstall it. Don't take a chance you could get parts in the engine and that is big $$$$.
Bruce
MoparMarv
Jun 3, 2006 05:39 PM
donhov
Jan 6, 2006 07:24 PM
NHDiesel
Sep 7, 2005 11:12 AM
04ctd
May 2, 2005 04:23 PM
tobyw
Aug 6, 2003 07:37 PM
