intake pressure test
Where exactly do you connect this set-up to?
Thanks,
Jay
How can I check for boost leaks?
Answer: The simplest way is to idle the engine and spray a mixture of liquid soap and water around every joint in the air intake plumbing. Remember not to forget the intercooler itself. They are prone to leaking at the welds.
Another alternative is to build you own pressure tester. This is fairly simple and the price is pretty reasonable at $10.
The parts needed
The tester is as follows: 4"x3" fernco plumbing adapter, reduce the 3" side with 3" to 3/4" threaded pvc bushing, male/male 3/4" x3/4"x 2" nipple, 3/4"x1/2"x1/2" T, pipe pressure gauge to (1) 1/2" side, place supply air nipple in other 1/2" side(grainger has supply valves with 1/8" NPT). Pull the intake hose from the turbo, slip 4" fernco on, and pressurize to 20 psi(Slowly).
The parts needed
Jay
Don't see how it's possible to only pressurize just the turbo.
You have a connector with a hose clamp right? Just crank it down, there is a ridge on the turbo inlet that should keep it from coming off.
Originally posted by weekend_warrior
So when it is mounted directly on the turbo, it sort of points to the back of the alternator, right?
Thanks
Thanks
Thanks for your response.
Now I just have to get it to pressurize.......
One thing I've noticed is due to the volumetric flow through a little air hose the pressure at the tank is nowhere near what the car sees. Sometimes I set the compressor to 50psi in order to get my vehicle upto 12psi. As long as there aren't any noises I think this is quite acceptable. Do you have a pressure gauge? I like to watch this to see just how much pressure the intake is seeing. Air should have no problem flowing past the compressor wheel of the turbo.
I have had air go right through my motor before as well but I don't understand this, cam timing shouldn't allow both the intake and exhaust valves be open at any angle.
I have the pressure at the tank set at 28, and another pressure gauge at the fitting(a cheater valve used when I paint set at about 20psi) that I cannot even open all of the way because it will pop the entire fernco assembly off of the turbo! Once I start to pressurize it, the fernco adapter starts to blow up like a balloon.
I will try it again this afternoon to see what happens. I might even take the hose off at the intake manifold to see if air is getting in there. Although when I tried it on Sunday, I could not hear any "hissing" noise on the intake manifold side.
Right around 25psi the boot will blow off the pressure tester, if you want a higher number you can rough up the plastic below it a little bit. Just make sure to do it in a radial fashion that way it won't leak. If you don't hear any noises that most likely means you have no leaks.
35" 05'
Nov 5, 2007 09:30 AM
Mark Craig
Sep 2, 2005 11:18 AM
