No 4th gear??
Old Jan 8, 2005 | 04:41 PM
CGA03's Avatar
No 4th gear??
Well i looked at a truck today, couldn't drive it, it was burried in snow behind 3 trucks. It has 231000 miles on it. The truck is a 97 2wd, 1 ton reg cab, auto with a welding flatbed set up. The cab is in good condition and the interior is a little dirty but would clean right up. He wants 2500 for it. He said the trans doesnt' shift into 4th, i couldn't verify this though. Any idea what would be wrong with it?? I thought the trans was totally, thats why i was lookin into a 45/5600. I was thinkin about buyin it and fixing it then selling it???
Old Jan 10, 2005 | 10:33 PM
cumminsdriver635's Avatar
If its in decent shape at all its worth 2500, but dont know what could be wrong with the overdrive. My Engine Speed Sensor went out, and i lost 4th gear, and converter lockup, but it also made my alternator not charge, and the A/C didnt work, and the speedo/tach didnt work, but I would think its something electrical or maybe some kind of shift valve? I dont know, but just a guess?
Eric
Old Jan 10, 2005 | 11:09 PM
CGA03's Avatar
Well i think it my be the tps, but that also sounds like a possiblity. I think i'm gonna get it any way i know i could make a dollar or 2 on it.
Old Jan 11, 2005 | 11:44 AM
CTD NUT's Avatar
It is most likely one of two sensors causing the lack of OD........it is either no signal or a very high voltage reading from the TPS...........or the trans temp sensor is reading the wrong resistance or there is a poor connection at the connector........I had the connector foul up on my 94........I pulled the pins out of the connector, cleaned and crimped them slightly to ensure tight contact with the sensor terminals and it worked fine after that.
OrangeBlackHD
Jun 22, 2010 07:11 PM
trout74
Aug 29, 2005 06:25 PM
SportTruck
Sep 2, 2004 12:28 PM
BUGCAR70
Jun 5, 2004 12:00 PM
mysterync
Jan 15, 2004 08:16 PM
