Input shaft NV4500
Old Jul 3, 2012 | 08:34 AM
traverler48's Avatar
Input shaft NV4500
If you change out your input shaft do you just pull the retainer and install the new shaft and bearings or do you have to redo the shims. I have done a search on this and its pros and cons. I don't know yet that I will have to but want to find out for sure.
Old Jul 3, 2012 | 07:54 PM
gorms's Avatar
If you have (or can get) a dial indicator to check shaft play then you should re-shim them. It's been a while but I think you have to pull the o/d gear housing along with 5th gear, then there are two plates that hold the bearing races and shims, one on the main shaft and counter shaft. I think the goal is .008 - .012" play. I would at least make sure you are within specs before you put it back together.
Muddin_dude06
May 2, 2007 06:50 AM
J Lent
Competition / Pulls / OffRoad
13
Apr 16, 2007 11:33 PM
nates90
Nov 15, 2006 11:13 AM
Captain
Nov 12, 2006 07:18 AM
