Starting Problems-Rare, but sometimes Floods?
Old Jul 3, 2012 | 06:40 AM
RoadDiesel's Avatar
well this happen about 4 or 5 times in the last one month..seems like when it sits overnight, when I go to start it, it turns over and over without starting. I have to hold the peddle to the floor before it starts..when it starts, it will run like its flooded and smokes for about 10 sec. then it runs fine..it only does this once in a while..No other probles, no evidence of water in the oil-water ..I sure dont want this to get worse..No mod's, 228,000 miles on it, auto..any ideas? glow plugs? I do use som "drews brew"..2 cycle mix/p.s..thanks in advance!!
Old Jul 3, 2012 | 07:43 AM
patdaly's Avatar
Probably an Injector sporadically leaking down.
Try running a heavy dose of Power Service thru it, hopefully it is just gunked up.
Old Jul 3, 2012 | 11:34 AM
RoadDiesel's Avatar
Hey thanks, anyone else??
Old Jul 3, 2012 | 12:37 PM
j-fox's Avatar
Ok, welcome to the site.
Now, it isn't flooded!!
It is air in the fuel system. Some of the 12 valves develope a leak in the return line at the rear of the head. It doesn't leak fuel at first but it is going to soon. Drivers side at the rear of the head.
The reason it sputters is it is blowing the air out the lines.
Your truck does NOT have glow plugs!! It has a grid heater that only works below 59 degrees.
Now, what I did with my 95 dodge when it did this very thing, was to loosen the clamp and slide the hose on about an inch farther. This fixed it. The metal line is a welded tube. The vibration cracked the tube/line. Get the hose on it far enough was all mine wanted.
Old Jul 3, 2012 | 01:57 PM
Tate's Avatar
The reason it is sputtering is because he is holding the pedal to the floor. Thats delivering all the fuel that pump can on start up, more than when its at WOT at 2k rpm. A LITTLE throttle is all you need when you are trying to start it when its tough to start.
Old Jul 4, 2012 | 06:28 PM
Lil Dog's Avatar
Test for leak down from leaking fuel lines.
Before you start it next time it sits, pump the primer about 20 cycles before you start. If it starts right up, you have a leak in the return/fuel lines.
Old Jul 4, 2012 | 07:02 PM
patdaly's Avatar
After re-reading the OP, I agree with the others, try priming it if it doesn't start immediately with 1/4 throttle.
Old Jul 5, 2012 | 06:52 AM
RoadDiesel's Avatar
Thanks for all the info. However, the truck is at the cabin & I won't be back there now for a couple weeks. I will follow up with a report when I check those suggestions!! tks
stanbnv
Jul 5, 2011 11:10 AM
Beast2B
Dec 8, 2009 01:44 PM
mr300x11
Oct 11, 2007 08:46 PM
Dave88LX
Mar 2, 2007 04:23 PM
G1625S
Nov 17, 2006 11:49 AM
