Inner Timing Chain Cover Gasket Leak!
I was recently on holiday pulling our 5th wheel and developed a Big Boy Oil leak! I took it in to some folks on the road & they said that it was the Inner Timing Chain Cover Gasket {I could actually part of hanging out}! They said that it would about 23 hours labor to fix it. We were all the way down in Brookings, Oregon from Seattle area so I decided to limp home and continue our Holiday leaking 1 1/2 quarts of oil every hour!
Does that estimate sound about right and is there any easier fixes? I am very mechanical but this sounds like it may be to much for me to tackle!
Oh, it is a 1997 1 Ton with a 12V 5.9
Bob
Bob
Last edited by murals4you; 09-11-2012 at 02:20 PM. Reason: Forgot to say what I had!
Hard to get a photo but this is the area they were pointing at on the bottom center area!
[IMG]<a href="http://photobucket.com" target="_blank"><img src="http://i388.photobucket.com/albums/oo328/bobpruner/TRUCK%20OIL%20LEAK/Pictures002.jpg" border="0" alt="Photobucket"></a>[/IMG]
I can't see your photo from work, but even pulling the cam gear rather than pulling the camshaft, you are looking at 7-8 hours minimum.
I would have a case available or time to wait on one to come in, I would just about bet a KDP problem as well, loose bolts wouldn't start that fast I would bet.
It sounds like everybody thinks it is a KDP problem when it starts leaking Oil that bad so quickly so I am thinking I may give it a shot! I guess my only fear is getting in there & getting stumped and then have to have it towed to a shop in pieces! I hope the cause of the leak is obvious once I get in there. Oh well, what the hell... I'll try it I guess!!
Bob
Bob
Oh, you guys have been very helpfull as I expected you would! Maybe I will get lucky & it will just be a gasket blew out! Ya, I know!!
But really, thanks, Bob
Our normal repair shop looked at our truck Friday to try to determine exactly where the leak was coming from & they think it may be a Crankshaft Seal & then of coarse the fan is throwing oil everywhere. How much you ask after hearing the last on the road estimate of 23 hours? 200 bucks!!!! So Monday they are going to install that, Pressure Wash everything & then have me monitor it to make sure the leak has stopped. I have my fingers crossed for sure!
I will report back! Thanks Guys!
Bob
Bob
