Injectors
Old Mar 12, 2003 | 08:39 PM
Trickytrae's Avatar
Injectors
Any good instructions on how to replace injectors on a 12V?<br><br>Thanks
Old Mar 12, 2003 | 11:03 PM
dsljunkie's Avatar
Re:Injectors
Injectors are cake . Make sure you have a good 3/4 crowsfoot wrench, it will make everything go easier. Just take off your intake&amp; valve cover, disconect all your high pressure fuel lines completly,and pull the injectors with a deep well socket. it took me a while to get the old injectors out but dont worry just keep wigglin em until they pull out. the #5 &amp; 6 injectors are fun . Good luck and I hope you went with the 370s, theyre worth it. ;D<br> Good luck<br> Wheels
Old Mar 12, 2003 | 11:29 PM
Lon's Avatar
Lon
Re:Injectors
Fabricate a pipe large enough to go over the injector and seats against the head. And long enough so that just some of the threads are showing at the top of the injector. Find a nut that will thread down on the injector. As you snug down on the nut it will draw up on the injector. Makes life a lot nicer especially the last two.
Old Mar 13, 2003 | 12:00 AM
4x4's Avatar
4x4
Re:Injectors
Rotor:
What is the &quot;Injector Install kit&quot; that I see advertised on some web sites. Is this a production version of the pipe and nut setup that you mention.
Old Mar 13, 2003 | 07:31 AM
turbospl311's Avatar
Re:Injectors
ok, what's the 3/4&quot; crows foot for? I started the process last night and did not run into anything that needed a 3/4&quot;. (Wondering if I missed something)<br><br>Anyway, I am borrowing an injector removal thingie tonight from JGK and doing the reinstall (Lon, gonna get to the injectors about 7:30 if you want to come over and drink a beer with Jay and I, PM for directions).<br><br>Also, doing a 4&quot; exhaust that I got from Rip. Gonna be a fun afternoon.<br><br>Don Miller<br>I'm not addicted .... well mayba a little<br>
Old Mar 13, 2003 | 07:53 AM
Trickytrae's Avatar
Re:Injectors
How about when you go to put them back in , do you have to have something to press them in?<br><br>Thanks
Old Mar 13, 2003 | 10:06 AM
gunracer1's Avatar
Re:Injectors
blow out the holes well and just slide them back in. it is easy. mike
Old Mar 13, 2003 | 12:10 PM
dsljunkie's Avatar
Re:Injectors
The crowsfoot wrench is for taking off the high pressure lines. I think you can get to them without it but it just makes it easier .<br> Wheels
Old Mar 13, 2003 | 07:32 PM
4x4's Avatar
4x4
Re:Injectors
[quote author=4x4 link=board=16;threadid=12195;start=0#115336 date=1047535220]<br>Rotor:<br>What is the &quot;Injector Install kit&quot; that I see advertised on some web sites. Is this a production version of the pipe and nut setup that you mention.<br>[/quote]<br><br>Anybody......What is the &quot;injector install Kit&quot; ? It is listed on the wildcat site and the tst site. What is in it? Do you really need it?
Old Mar 14, 2003 | 11:01 AM
dsljunkie's Avatar
Re:Injectors
The install kit includes new copper washers (use the thinest ones) some rubber boots (throw away), some rubber o-rings (use), and some copper line guides for the return line (use). I would definitly get the install kit. Good luck.<br> Wheels
Old Mar 14, 2003 | 12:28 PM
nevrenufhp's Avatar
Re:Injectors
Also depends on where you get the injectors. I got mine from PDR and the install kit comes with the injectors unless you specify otherwise. I second that motion:370's are worth it! With a 0 plate in about stock position it had very little smoke.
Old Mar 14, 2003 | 01:09 PM
Re:Injectors
As someone who did the injector install last night, it was very easy. Just remember to use the thinnest washers. The performance gain is very niticable. Also, the EGT raises incredibly fast, so if don't have a gauge, get on! I had not been over 900 deg before and hit 1200 last night on the leak test run.<br><br>Don (like a kid with a new toy) Miller<br>97 2500 LWB EC, #8 plate, 3k gov springs, 370 injectors, 16 deg timing, 4&quot; shorty RIP Exhaust, Scotty II, Full Isspro gauges
Old Mar 14, 2003 | 04:05 PM
Don M's Avatar
DTR Advertiser
Re:Injectors
Dont feel bad about EGT's. My probe is in the tailpipe back at the rear of truck just about even with the spare tire and I can get 1400 there easily. <br><br>Pre-turbo just melts the probe off.<br><br>Hope ya know........Im just kidding <br><br>Actually with the big turbo I have....the truck never gets over 1300 even with super super super large injectors.<br><br>Don~
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
