injector lines leak
took my injector lines off to retorque the head bolts a couple months ago and checked yesterday and #4 and 5 where leaking pretty bad from between the line and injector. took the nut off and cleaned the seat and put it back on but it still leaks a fair bit. is there an oring or some kinda seal that might b broken in there? looks to me like just a tapered seat, metal on metal contact seal. what am i missing?? seems like this should b able to be done and not hafta replace lines or injectors every time. or should this b an excuse for some 5x12s?
If you have a 3M Scotchbrite pad or fine emery, you could just touch up the end of the injector line and clean out the injector. Doesn't take much of a grain or small piece to cause a leak.
You're right, they have just a tapered seat, no o-rings and you don't need to replace the lines when you remove them.When you reinstalled the lines, did you torque the nuts? I only ask because over torquing injector lines is the leading cause of leaks and not too many people have the proper cut-out socket to torque them. The spec is a surprisingly low 18ft/lbs - not much at all. Over-torquing them can damage the seats. Check the seats on the leaking injector lines for any damage - cracks or deformities. On a slightly damaged seat, I've had luck working the nut back and forth while tightening it up - sort of re-forms/seals the seat.
thanks guys. just cleaned it again and now its leaking worse. now about that overtorquing thing....i think that might b it
lol. See my train of thought was if its leaking it must b loose, so i kept cranking on it
guesstimating around 50-60 ft-lbs? but i did notice that the threads looked bottomed out and thot that was weird. o well, i needed new sdx 5x12's anyways right?
Great Attitude...if you get lemons make lemonade
Enjoy the new Injectors
Haha it easy to have a great attitude about wrecking stock stuff cause then I have a legit excuse to get upgraded performance parts!
but good stuff to know so I don't wreck the New injectors or lines......
Katmandu
Sep 10, 2006 06:08 PM
NJDiverDan
May 19, 2006 05:03 PM
