Idle is rought and sounds like injecter is popping
Old May 4, 2012 | 09:14 PM
fearlessgordon's Avatar
Unhappy Idle is rought and sounds like injecter is popping
Ok I replaced the Orings in my 1994 12 valve it has a p7100 pump in it The Orings that go on the delivery valve housing. I put it back together making sure i replaced them in the same port they came out of .Now it idles terrible real rought . As i give it the peddle going down the road it seems to run ok but sounds like it knockes what did i do wrong? could use some help.
Old May 15, 2012 | 02:11 PM
pic_jon's Avatar
Did you touch &/or loosen the two nuts on either side of the delivery valves?
Old May 15, 2012 | 05:56 PM
replaced O rings
yes i took them .both loose so i could pull the housing off
Old May 16, 2012 | 04:24 AM
Tate's Avatar
You just messed up the calibration of each barrel. Send it off to a shop to have them fix it.
Old May 16, 2012 | 09:04 AM
Damm i had better do it i didnt know they were set at a specifice place. thanks
Old May 16, 2012 | 02:54 PM
infidel's Avatar
The o-rings you replaced are just for keeping dirt out of the threads, they don't seal in fuel.
60valves
Apr 16, 2015 07:32 AM
xpetecx
Sep 13, 2010 11:01 AM
12valvin
Aug 17, 2009 06:30 PM
birneyj
May 3, 2009 06:02 PM
rnb_cattle
17
Jan 15, 2008 07:09 AM
