I'm getting a wobble in the engine/trans
Old Dec 6, 2010 | 07:50 PM
yellowrosefarm's Avatar
Early 98 12V, auto, 125K. When I drove the truck last weekend I noticed for the first time a cyclical wobble in the engine/trans. It does it in park at idle and is a regular as a heartbeat. Smooth, count 4, wobble, count 4, smooth, count 4, well, you get the idea. It is also there through all ranges of forward motion but seems more pronounced under load. From reading other posts here I'm thinking maybe torque converter bolts coming loose. I won't have time to pull the inspection plate until this weekend but it's not my DD so it won't get worse sitting in the drive. Are there any other suggestions for things I should look for when I have it in the shop?
Old Dec 7, 2010 | 10:43 AM
infidel's Avatar
Check that the engine and tranny mounting bolts are tight.
Old Dec 7, 2010 | 02:23 PM
Will do, thanks.
Old Dec 7, 2010 | 02:47 PM
BigIron70's Avatar
Cummins Guru
Check harmonic balancer bolts are tight and the balancer hasn't shifted on the center hub.
Old Dec 7, 2010 | 08:20 PM
cj360trider's Avatar
BigIron70 had my thots exactly
725Gus
Mar 6, 2014 09:49 AM
M Penwald
14
Mar 26, 2011 08:41 PM
EverydayDiesel
19
Aug 2, 2007 05:36 PM
Jezzhuntin
Apr 11, 2007 04:52 PM
BlackSheep5
Jul 4, 2006 11:46 PM
