4x4 High not engaging
Old Nov 22, 2010 | 05:58 PM
lilred's Avatar
Last couple times I tried to use 4x4, could not get it to engage, no interior 4x4 light no power to the front wheels, the 4x4low works perfect. Not familiar with the transfer case in this truck yet but sounds like I'm about to be, any thoughts? Thanks...
Old Nov 22, 2010 | 07:36 PM
cj360trider's Avatar
if 4L works then so shud 4H. both engage the chain in the tcase. are you moving the truck when trying to engage 4H. im assuming you are. (and yes i know what assuming does lol) check all of your vacuum hoses going to the tcase and front axle
Old Nov 22, 2010 | 10:46 PM
Tate's Avatar
If 4lo works, that indicates that the CAD is operating correctly. I'd make sure your linkage is adjusted properly and that its moving far enough to engage 4wd.
With the truck off and in 2wd, make sure the front driveshaft spins freely. Put it in 4hi and check again. If it doesn't turn, jack up one of the front wheels and check. If the front shaft still turns, you're not engaging in the t-case. If it doesn't turn, it could be the vacuum switch on the t-case.
Old Dec 8, 2010 | 05:49 PM
lilred's Avatar
OK, had someone look at it while they were doing something else and they said its the 4wd actuator, that the front driveshaft spins but isnt spinning the wheels. Looks like an easy piece to replace ($100 part), except other than the electrical there was only one hose leaving the actuator and it was capped and tucked inside the frame! I'm confused, the 4wd worked fine a month ago...Thanks again for any help...
Old Dec 8, 2010 | 09:37 PM
Tate's Avatar
There should be two vacuum lines going to the actuator.
Old Dec 8, 2010 | 10:33 PM
rebal's Avatar
yes should have 2 lines one locks in cad the other unlocks the cad
Cory Swanger
Dec 8, 2014 10:38 AM
olwhitey
Dec 14, 2008 03:11 PM
Luckyrogue
Jul 26, 2008 07:42 AM
Kman9090
Jan 29, 2005 07:14 PM
