4x4 not engaging!
Old Jul 24, 2008 | 12:31 AM
Luckyrogue's Avatar
4x4 not engaging!
The other day I needed my 4-wheel drive and needless to say it did not kick in and I was stuck. The transfer case is shifting into gear fine and that's why I thought the 4x4 was working, The axle is just not engaging. The vaccuum lines appear to be fine and after about an hour of fighting the mud it kicked in and I pulled right out, after unhooking the stock trailer. Later that day I had to go back in and pull out my trailer. It took about 10 minutes before the axle finally engaged, pulled the trailer out just fine. Now my 4x4 light still has not gone off but the axle does seem to have disengaged because I feel no tension when turning. Any Ideas or similar problems from anyone else?
Thanks
Luke
Old Jul 24, 2008 | 12:45 AM
markman's Avatar
I had a similar experience, and had to really search to find the vac. leak. it was bundled up along the edge of the fire wall but once I replaced the cracked vac line with a fresh one, I have had no problems hooking up.
Old Jul 24, 2008 | 02:28 AM
Luckyrogue's Avatar
Thanks for the input markman. Where at by the firewall do the vac lines come up? I've looked for vac diagrams but have had no luck. Thanks again!
Old Jul 24, 2008 | 03:47 PM
stackx2's Avatar
it could be the axle drive motor if it gets bent or even age will cause a leak in the diaphram and act like that . my 01 was doing all the same things I ordered a new moter from quad 4x4.com and it works great now.
R
Old Jul 26, 2008 | 07:42 AM
markman's Avatar
The vac line runs through the loom of wires along the edge or top of the firewall. I looked at the joints and connections first but found a cracked line hidden in the loom.
Cory Swanger
Dec 8, 2014 10:38 AM
lilred
Dec 8, 2010 10:33 PM
olwhitey
Dec 14, 2008 03:11 PM
Kman9090
Jan 29, 2005 07:14 PM
