Idea behind the converter lock-up switch?
Old Aug 7, 2005 | 07:06 PM
XLR8ER's Avatar
Quick and simple- Whats the theroy and does it apply to pulling?
like possibly the ability to keep it in 3rd gear-locked up?
thanks and sorry to beat a dead horse
Old Aug 7, 2005 | 10:13 PM
Loud&Obnoxious's Avatar
Well the idea is to transfer more hp to the ground instead of leting your tranny slip it away. When the tc is locked you are 1 to 1 with the engine no slippage its like a manual tranny. When its locked it doesn't create the heat that you get when your TC clutch slips so it runs much cooler however it is not good for mpg and is hard on the engine and if not used properly can be bad on the tranny too.
Old Aug 8, 2005 | 07:05 AM
j-fox's Avatar
The stock converter ( and many aftermarket ones ) are too loose in fluid coupling. So, some ( including myself ) try just putting a lock-up switch in parallel to the computer. This way we can lock it when we want. Then it is much more efficient.
Problem comes when we find out the stock trans is poorly built and the converter and other clutches do not have correct pressures to apply them. Things slip, trans gets cotaminated and them failure. Complete rebuild then is needed. It is even worse with a modded Cummins.
Just wanted you to know in advance!!
Old Aug 8, 2005 | 07:49 AM
XLR8ER's Avatar
ok then, mines done ! so I guess I would like some helpful hints on the proper operation, or do I get rid of it? I kinda like with the od off
fourspeedracer
16
May 17, 2007 05:53 PM
ataboy9026
Jun 9, 2006 09:08 PM
Begle1
Jul 13, 2005 04:13 PM
mr T
21
Jun 1, 2005 08:48 AM
mr T
May 15, 2004 09:41 PM
