Lower ball join problem HELP
Old Aug 7, 2005 | 04:55 PM
downlow's Avatar
Lower ball joint problem HELP
I changed the lower and upper ball joints but they still wont align because they said the lower passenger side is bad??? So I pulled it back apart and upon closer inspection the lower ball joints seat (angle part) is worn some WFT it didnt break off or anything like that. So how do I go about fixing it its part of the whole dam axle assembly. Kinda need this thing fixed as Im heading to Canada SOON and I am need of a alignment.
96 2500 4x4 reg cab Cummins
Old Aug 7, 2005 | 10:02 PM
XLR8ER's Avatar
how, EXACTLY did you set\install the joint?
Old Aug 8, 2005 | 02:58 AM
downlow's Avatar
Setup
I installed it the same as drivers side. Put the new joints in and tightened evenly, not top 1st then bttom. Also I didnt us a air gun ect..I dont like using them during assembly. Did I go astray somewhere in the process?
Old Aug 8, 2005 | 08:35 AM
XLR8ER's Avatar
That sounds ok to me, I was just making sure you didnt set the truck on it or use a jack?
sorry I dont have better advice?
Swamp_Donkey
ABDTR #5
Nov 18, 2009 07:04 PM
DBLR
Sep 10, 2009 11:52 AM
WhozNxtLS1
24
Feb 28, 2009 07:49 AM
smog2001
Aug 10, 2007 09:32 AM
RonP
16
Jun 16, 2006 06:57 AM
