I need a measurement please...
Old Dec 9, 2009 | 09:41 PM
pcgym's Avatar
I will be grateful if someone with a 1995-1997 2500/3500 Club Cab 4WD NV4500 can measure the rear drive shaft please. It needs to be from the center of the front u-joint to the center of the rear. I am doing a V10 Cummins swap... the V10 is an auto and my 5 speed is from a 2WD. I am making the switch over the weekend and need to have a drive shaft made. Thank you in advance for the help... hope it's not too much trouble/will save me some time-
Old Dec 9, 2009 | 11:34 PM
Tate's Avatar
I are confused. Why do you need the DS length from a 4by if you are putting a 2wd tranny in? You will probably want a carrier bearing and a two piece driveshaft, because that shaft will be about 8' long.
Old Dec 10, 2009 | 10:18 AM
pcgym's Avatar
I am mating the 2wd 5 speed to the V10 transfer case... I already have the new mainshaft and housing ordered and should arrive today. I will not even see the V10 truck until it's time to do the switch. I thought I would get a jump on the shaft but I don't know what I am looking at yet as I have not laid eyes on the V10 truck yet. I don't even know if the 4WD is a two piece system either... that's why I am in need of assistance. I am grateful for any help or advice- Thanks
Old Dec 10, 2009 | 10:05 PM
Tate's Avatar
Auto and 5 spd had different spline count on the t-case input. Is that getting changed as well?
I think the CC/LB 4bys have a carrier bearing, but I can't confirm since I don't have that configuration.
Old Dec 11, 2009 | 08:37 AM
patdaly's Avatar
CC/LB definitely has carrier bearing in 4X4, I just can't get to mine to measure it right now......
Old Dec 11, 2009 | 07:30 PM
pcgym's Avatar
Interesting note on the input spline count... did not know that. When I ordered the main shaft and housing I was told it was all I needed but it is all a learning experience for me. I will definitely check into it... thanks. The drive shaft will have to wait until next week anyways. Thanks for all the input-
Old Dec 11, 2009 | 07:42 PM
patdaly's Avatar
Yep, Autos is a 23 spline, Manuals are 29.
Old Dec 11, 2009 | 08:13 PM
pcgym's Avatar
Well lucky me... I guess I'm on the hunt for an input shaft now. So much for the switch for Monday... was hoping to get this done before it gets too close to Christmas. I am grateful that each of you read this post... can't imagine trying to do this without a little advice. Thanks again and please let me know if anything else comes to mind-
rbrettctd
Aug 10, 2007 05:15 PM
royta
Nov 6, 2006 08:19 AM
Scotty
Mar 13, 2006 07:09 PM
Crimedog
Mar 18, 2004 07:29 PM
dcorneli
Mar 12, 2004 08:13 AM
