pump question
Old Dec 11, 2009 | 07:32 AM
dieselman97's Avatar
pump question
ok putting a new injection pump on my 97. do i need to do anything to the pump as far as rotating it until #1 is firing before i put it on the engine?? or can i put the engine at tdc and then just slap the new pump on??? I know i will have to time itonce on. what would you all recomened for timing just put in stage 3 cam. stock hx 35, and a #10. with 5 speed tranny??
Old Dec 11, 2009 | 07:52 AM
G1625S's Avatar
Ask the pump builder where the pump is pinned at, then you'll know where you're at for the install. 16.5* seems to be the go-to number for a street driven 215 pump. I've got about 17* and am very happy with it.
Old Dec 11, 2009 | 08:47 AM
dshane62's Avatar
if the pump is pinned which it should be just use timing pin on your engine roll it to tdc and stab the pump if its a p-7100
Old Dec 11, 2009 | 08:53 PM
yes it is a p pump. i took the timing pin out of pump like manual says. turned the pin around and it went in easy. if the pin goes in then is the pump firing on # 1?? just curious. worked on many a rotary pump but i have no idea why bosch didnt key it.
Old Dec 11, 2009 | 10:01 PM
dshane62's Avatar
make sure that the engine is #1 at tdc push timing pin in and bar the engine
till the pin pops in thats tdc. the pin on the pump was keeping it at #1 firing.
i usually dont turn the pin around till i put it on. make sure that you use some
brake clean or carb spray on the shaft and hole in gear so it dont slip when you tighten it up good luck only hard thing is having enough room to set the pump i did mine by myself and it sucked i used a cherry picker to hold the pump
ARbowhunter7
Mar 24, 2012 11:03 PM
crewcabxlt
Apr 3, 2009 06:31 PM
3500_CTD
14
Feb 5, 2008 08:33 AM
ScreaminEagle
Oct 31, 2007 03:31 PM
TPilaske
16
Nov 22, 2002 08:15 PM
