I was attempting to pull a dumpster - PROBLEM or not?
Old Aug 14, 2007 | 09:18 PM
Common's Avatar
My buddy has an '07 Cummins and he kept spinning all 4 tires....
So I figured what the heck and went at it - neither of us could move it - took a Bobcat and my truck to move it...
Anyway...
After I was done, my BRAKE light came on and didn't shut off until I shut the truck down...
It hasn't come back on and my fluid is dead on...
What would cause that?
Old Aug 14, 2007 | 09:46 PM
AggieJustin's Avatar
If you spun your tires, that's the computer signaling that it thinks there a problem with a speed sensor because it detected conflicting signals (one tire spinning, another not).
As long as it doesn't come back on, you should be OK.
Old Aug 16, 2007 | 06:28 PM
rootremblay's Avatar
Mine does that if I power brake really hard, it always goes off after I shut it down though. Don't worry bout it, IMO
Old Aug 16, 2007 | 06:31 PM
CTD03's Avatar
did you try to tap the brakes after that my light comes on and then i just tap the brakes and it goes off
Old Aug 16, 2007 | 07:09 PM
iker42's Avatar
Anyway...
Big Dumpster?
Old Aug 16, 2007 | 07:16 PM
madhat's Avatar
Administrator/Jarhead
My truck does that when I'm running through the sugar sand back home. Lots of spin... after I driver around for a minute on a normal road, it goes off.
I would not be worried...
Old Aug 16, 2007 | 10:09 PM
bsj04's Avatar
mine has done that befroe too after pulling out a truck in the snow. as far as moving to dumpster how long was the chain? short chain + high hitch + low point on dumpster = should have moved with just the truck. help get a little weight and traction on the rear. might help out next time
Old Aug 16, 2007 | 10:12 PM
Common's Avatar
Originally Posted by iker42
Big Dumpster?
Yeah, sunk in gravel and mud...
Full of concrete and dirt...
Old Aug 16, 2007 | 10:16 PM
iker42's Avatar
ouchie, shouldnt be anything to serious tho.
NJTman
Nov 11, 2022 03:48 AM
07CTD4X4Sport
36
Jan 28, 2010 06:25 PM
vj_M
Apr 12, 2009 11:11 PM
Homestead
Jun 18, 2003 08:38 PM
