HX35 upgrade Q's
Old Oct 16, 2016 | 02:10 PM
greasy's Avatar
HX35 upgrade Q's
#10 fuel
3K GSK
50hp DDP injectors
full instrumentation
triple disk converter + upgraded 47rh
My VB is causing a stiff engagement in the TC and barking the turbo if I don't catch it in time and back out of the throttle for the OD shift. Unfortunatly the turbo has barked a few times too many and it's out of spec now and needing rebuilt. Under boost I'm getting some minimal contact on the turbo fins and housing, I could hear it so took the intake boot off and see some scuffing. Truck is parked until fixed.
I'm looking for a slight upgrade that will handle more abuse (also intend to address the VB and TC engagement)
what's a good value, rebuild my HX35 or step up to a 60mm fat shaft?
Old Oct 16, 2016 | 02:18 PM
greasy's Avatar
Guess I'm looking for a reputable shop or place to send the turbo for a big durability and slight performance boost focused on towing heavy. Slightly bigger housing to reduce EGT and wouldn't might a slight spooling delay to decrease in EGT under mid to full boost.
It's not a race car, I haul hay and farm equipment.
Old Oct 21, 2016 | 05:25 PM
Required_Field's Avatar
I have not done this, but I have seen a few folks in forums recommend G-pop Shop, http://gpopshop.com/
Old Oct 26, 2016 | 12:52 PM
greasy's Avatar
Rotomaster New Turbo Cartridge Assembly 94-98 5.9L Dodge Cummins
Old Jan 7, 2018 | 11:40 PM
greasy's Avatar
the rotomaster core is working good, just an update
Old Jan 8, 2018 | 10:48 AM
Midnite's Avatar
Thanks for the update. I would've expected you might need to upgrade to something like an S300 type. I'm no turbo guy, but from what I understand it's a lot stronger than the HX35 or 40 and can tolerate a lot more abuse.
Good to know the Rotomaster is working well for you.
sshort
Feb 26, 2009 10:32 PM
AlanF
Jan 17, 2008 08:07 AM
rbrettctd
Apr 18, 2007 10:37 PM
67HotRod
Oct 28, 2005 07:51 PM
bwat4
Dec 15, 2004 05:08 PM
