How reliable is the cummings 5.9?
Guest
Posts: n/a
The black smoke is normal in the bottom of a gear like that (low rpms), the motor is running high boost and high load but can't quite catch up fast enough so the black smoke results.
Well there is a good reason why I want a 98 12V and not a 24V.
However I'd say that this would be biased since we are in the 12V forum, I bet there are 24Vs out there doing it they are just a bit fewer and further between. I think the motor itself is as rugged but the fuel system, well that is another story....
Doogie & Matador,
do you guys run fuel additives at all? I noticed mine smoked gray some at idle, and blue smoke in the morning even if it's 75 when I leave for work.
I put an extra dose of Amalgamated diesel additive in a couple tanks and drove it kinda hard to boot. Smoke has cleared up a lot. Might get something like Stanadyne or Howes and run a few tanks with that. What I did was wait until I was down to 1/4 tank then put enough in for 3 tanks to give it a concentrated dose. Seems to have worked. The original injectors & pump are working quite well at 352k.
Vaughn
Vaughn
Guest
Posts: n/a
I've found using higher cetane fuels reduce the amount of grey smoke, so I guess you could say an additive would also help reduce this. I found when taking my injectors out that they were covered in carbon pretty good, a bit thicker than what I was looking for. I guess that was my warning to stop driving it so softly, diesels love to be ran hard, running them soft will only kill them. I use Redline DFC but it still doesn't seem to help the problem from what I notice, I've tried not using any and using more than enough. No noticeable chance either way, but pour a little WVO in and the cetane boost is visible in the lack of smoke and audible in the almost gasser like sound.
Originally posted by infidel
Notice that these trouble free high miles are all on 12 valves. I've personally never seen a 24 valve break 300k without major repairs.
i traded a 99 ford diesel for a 96 12valve cummins and it was the best thing i ever did. i bought it 5 months ago with about 100k miles on it and it runs great. i floor it where ever i go. i tow race cars and other stuff. you can't kill that motor. when you buy it make sure you use mobil delvac 1300. great oil. i have 12,000 miles on that oil and it is still as good as the day i put it in.
MacKenzie
I do run Stanadyne or Power Service additive in the winter here in ND. I replaced the injectors about 10000 miles ago. I havent run additives for probably 15 thousand miles or so. Maybe I should add some and see what happens.
I notice mine smoke seems to be a lot more blue than black sometimes in the morn but then clears up after that and it doesnt do it on a regular basis.
Vaughn i haven't used any additives, i plan to use something to clean the injectors. mine smokes but only when i give it wot. in the last months i have been getting more smoke at startup but thats it. chris
